Go to Post Only two letters and one punctuation mark can describe my feelings about this... NNNOOOOOOOOOOO!!! :( - Qbranch [more]
Unread 17-05-2016, 23:34
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: Need a good table top scrolling CNC!
Originally Posted by JohnFogarty View Post
Is this Velox router any good?
http://www.veloxcncrouters.com/#!36w/c1xeg
Yes, but I suggest upgrading from the router to a spindle so that you can adjust the speed of your cutting tool.
Also it depends on the table you mount (not place) it on, make or buy a real sturdy table and it will be fine.
We absolutely love our VR50X50 with the HSD 3 HP spindle.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 17-05-2016, 23:35
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Originally Posted by RoboChair View Post
I believe you can get the Velox with a water cooled spindle, but it's way overkill. You would have to be running the machine like a production shop before it would be worth considering. Only thing it really makes easier is changing spindle speeds with the G-code and overrides from the Mach3 controller program.
I'd disagree. The water cooled spindle has less run out than the router. When your working with small end mills at a high RPM it can make a big difference with how fast your feeds are and tool wear. I've run machines with both and I definitely prefer the proper spindle.
Edit: The water cooled spindles are also much much quieter.
2016: FRC 865 Mentor
Unread 18-05-2016, 00:08
AKA: Clint Brawley
FRC #0364 (Fusion)
How does that compare to a non-water cooled spindle like the HSD 3HP we have?
Clint Brawley
USAF 1992-2013
Unread 18-05-2016, 00:25
mman1506's Avatar
no team (WARP7)
Same goes for the HSD, generally any spindle designed for CNC machining with a ER collet will be superior to a re purposed wood router.
We also have a fan cooled HSD spindle on our router that I love.
If your buying a spindle I'd highly recommend getting one that's water cooled or uses a fan that's not coupled directly to the spindle motor(HSD's are usually setup like this). They are waaay quieter.
Unread 18-05-2016, 00:43
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
I agree with Devin, you can do a lot with the velox router. We have the same Velox and love it. We don't have access to a 220 volt line so hence the router. If you don't have the money for the spindle or adding an new 220 volt line, don't sweat it, the router will do fine.
If we ever get enough space, maybe a second one with a spindle will be what we get but for now, we are very happy with our purchase.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 18-05-2016, 00:57
mman1506's Avatar
no team (WARP7)
865 has a 60x60 XZero Demon CNC Router with a HSD spindle.
Here's a video of it in action
All in it was about $10k CDN which was a killer deal considering the quality.
Some advantages of it over the Velox and other CNC routers near its price point (and things to look out for when buying a CNC router):
Ballscrews - The Velox has ACME screws that are inferior in every way besides cost. It's not uncommon to lose over 50% of your stepper motor's power due to friction when using acme screws. The anti backlash nuts also wear quickly and become imprecise.
Linear guideways - Most budget CNC's use circular linear rails which are significantly less rigid. I'd stay away from any machine using bushing on it's linear rails.
A "real" spindle - The re purposed wood routers on many CNC's were not designed for CNC machining and may have a large amount of runout. While they may be equipped with speed control they quickly loose torque at lower RPM's.
That's not to say that the Velox and other budget CNCs are bad. The Velox looks like an awesome out of the box option for teams. It took us a whole season just to get our CNC setup and it's still not 100% done. In my opinion the most important part of any CNC machine is having someone who knows how to operate it. Things like fixturing, CAM, feeds and speeds can be difficult to learn. Our team has access to 5 CNC machines (2 mills, 2 routers, 1 lathe) and we still rely on laser cutting sponsors to do the majority of our machining due to a limited amount of experienced CNC machinists and time constraints.
Unread 18-05-2016, 01:03
mman1506's Avatar
no team (WARP7)
You can purchase VFD's the convert single phase 110v to 3 phase 220v like this one
Unread 18-05-2016, 01:30
RoboChair's Avatar
AKA: Devin Castellucci
I'd disagree. The water cooled spindle has less run out than the router. Edit: The water cooled spindles are also much much quieter.
While generally yes a normal router has more runout, Velox has a special spindle collet(looks like an ER collet) that eliminates most of the runout issues. It is louder and the torque can be an issue, I will agree with that. If you really want a proper spindle, buy one from China for 200-300 dollars separate from who you get the machine from(we will probably be doing this for next year).
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 18-05-2016, 12:40
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
We are evaluating that question right now. Its the repeat ability we are looking into between the two machines and the face that one weighs more and may be more rigid resulting in better accuracy.....
Faridodin "Fredi" Lajvardi KD7WKD
Unread 18-05-2016, 18:04
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Also ShopBot is good to consider.
Unread 18-05-2016, 18:19
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
Which one, specifically?
John Fogarty
Unread 18-05-2016, 19:08
Mulcahy's Avatar
Mulcahy Mulcahy is offline
FRC #0987 (High Rollers)
Mulcahy is on a distinguished road
987 has used a shopbot bt-32 (the cheap one!) since 2013. Its great for fast prototypes in aluminum, MDF and plastic. As far as accuracy goes, it is not accurate enough to make transmissions and gearboxes, but can make anything that can take a tolerance of 0.010". A part that would take all day on a 3d printer, can be made in a few minutes on a shopbot and will be much stronger. Ours has a standard wood router spindle, which has been able to cut 1" aluminum, but I would recommend keeping it under 1/4" for most aluminum parts. We have had success with plastics and wood up to 3" thick.
Unread 18-05-2016, 20:42
techhelpbb's Avatar
PRStandard with HSD spindle is around the sub-$15k range.
Unread 19-05-2016, 03:10
Frank Neuperger Frank Neuperger is offline
FRC #0842
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
I am helping Falcon robotics through the machine selection process.
Can the owners of both the velox and the Laguna, share with us the "typical" repeatability and accuracy that you have been able to get from your machines. i.e. have you put a dial indicator on the machine and tried to return to a point with each axis? How close can you get when you return?
Is anyone making aluminum transmission side plates with their CNC router. what kind of bearing hole diameter tolerance are you holding? How about center to center hole tolerances over say a 3" to 6" span.
What is the linear bearing rail diameter on both Laguna and velox on X and Y axis. This could help rationalize machine stiffness questions.
The 2 x 3 Laguna at 425 lbs with ball screws and water cooled spindle claims 0.002" repeatability.
The 4 x 4 Velox at 300 lbs with lead screws and router head claims 0.001" repeatability.
Would you not expect the repeatability to be better on the Laguna?
Velox will not share typical repeatability test results. I have not asked Laguna yet for repeatability data.
Also found out that Velox uses 2 NEMA 34 950 oz-in steppers for lower axis (Y) and single NEMA 34 on X axis. Velox uses 400 oz-in NEMA 23 on z axis.
Laguna uses single NEMA 23 on each of the 3 axis.
So Velox seems better on the motor torque and resultant effective stiffness in the drive train. Laguna has more mass and possibly structural stiffness. Why is the Velox repeatabilty claim twice as good.
Looking forward to data from anyone that has tested their machine.
FRC 842
FTC 4314
Team 0x27 (NURC, Sparkfun AVC)
Formerly with FRC 39 (now in cryosleep).
Unread 19-05-2016, 11:08
AKA: Ledge
Thanks Frank! Yes if anyone can answer Franks questions that would be great!
