Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 18-05-2016, 09:25
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: One or Two Drivers??
We only use one driver (me). It is simply a lot faster for me to do everything, than trying to communicate what I am trying to do with another person, and tell them exactly what to do.
But I can only say do what your team finds best for you guys and your bot
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 18-05-2016, 09:33
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is online now
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
We change it up based on the robot's functionality. In 2015, our robot was simple so we only used one driver, since the only mechanism on our bot needed to work well as the driver moved around the field. This year, we used two, since our shooter mechanism worked independently of our driving.
Basically, if a feature or mechanism needs to work at specific times while moving (intake or A-defense manipulation for example), our base driver gets control of it. If it works independently (e.g. shooter or hanger), it's given to our copilot.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 18-05-2016, 10:08
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
We use two drivers and have found it to be very reliable for us. While two drivers will never be able to communicate as well as one driver, there are often a lot of tasks that need to be taken care of at once.
I have found that, by using a two-driver setup, I can focus on the task of getting around defense and not worry about forgetting to turn the shooter on or raising our arm over defenses.
There is also an objective bonus to using a two-driver setup: you get more analog inputs. This isn't necessary for every robot, but most controller setups are limited to two analog inputs (one for each thumb). Some manipulators really like having analog control, and you probably want analog control for your drive train too.
While it might seem like two-driver is madly inefficient because of communication issues, a little practice can seriously mitigate that, and makes a lot of complex multitasking maneuvers much easier.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 18-05-2016, 10:21
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Remember too that while technically having one guy do it all can be more efficient than two people working together, the advantage of the latter is that you're teaching at least two of your team members to work together. There's serious value in learning how to work well and communicate effectively with other people, learning to keep their cool in heated and stressful situations, and so on.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
