Go to Post Robotics competitions take place in the same "perfect" environment that basic physics equations take place in. :rolleyes: - Branden Ghena [more]
  #32   Spotlight this post!
Unread 18-05-2016, 10:14
tstew's Avatar
tstew tstew is offline
Alumni
AKA: Timothy Steward
FRC #3928 (Team Neutrino)
tstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud of
Re: 2016 IRI - Rule Changes and Reasoning
Originally Posted by Chris Fultz View Post
10. 5.4.4 - In Eliminations, up to THREE tied MATCH SCORES between two alliances will be re-played. If the 4th re-play results in an additional tied MATCH SCORE, the published FIRST tie-breakers will be used.
I have a few questions in understanding how this will work.
To make sure I am understanding this correctly could you confirm that the scenario below is correct.
Match #1 - Tied (tied match #1)
Match #2 - Red wins
Match #3 - Tied (tied match #2)
Match #4 - Blue wins
Match #5 - Tied (tied match #3)
Match #6 - Tied (tied match #4, FIRST tie-breakers will be used)
How will these extra tiebreaker matches fit into the playoff schedule with the other matches?
Which tied match will be used to calculate FIRST tie-breakers?
