Mecanum wheels on the front, regular wheels on the back
Need a little help here. This mini-robot has Mecanum wheels on the front and regular wheels on the back I know I've seen a discussion on how well/poor this would work, but I'm not finding it.
Appreciate either a link, or a quick comment on what you think of this drive. (Ignore the details on the video, 3 of the 6 drives they built have the Mecanum wheels on the wrong way.) |
Re: Mecanum wheels on the front, regular wheels on the back
They aren't powered, and the Instructable for the project actually calls them omni wheels.
It's the combo of driving a 1/2 mecanum that I'm thinking about. |
Team SCREAM's 2014 bot had traction in the front mecananum in the back to help with turning. When I asked them about it they said they preferred it over omni wheels.
Well, assuming you want to power all of the wheels, the forces generated by mecanum wheels has been discussed extensively. Similar analysis can be done for any combination and configuration of wheels.
For example, if using vector analysis on a 4-wheel partial mecanum drive: -Two of the wheels can be modeled as described in the second linked pdf -The other two will provide propulsive force only in the front-to-back direction. The 'only' side-to-side force will be friction, which will be whatever is needed to negate any forces acting on the wheel in that direction, up to the point where static friction is overcome.* (*This is, of course, an approximation, YMMV) |
Here's something from the 2015 offseason that might be helpful. 585 built a drivetrain with two front mecanums and a single, perpendicular, rear omni. What do you want to accomplish with this layout? Or are you just wondering how it would behave? |
#7
I'm interested in how it would work. I put that wheel layout on a VEX square bot frame. I programmed it to be a regular Mecanum layout and it doesn't work well. Forward reverse works, but turning has the rear scrubbing.
The single rear omni is interesting since that would help the turning issues, and while moving forward the rollers would work well. So with my little build failing with what could be the wrong code, I thought I'd try some math, hence the search here. |
#8
5132's bot this year was a 4 wheel drivetrain with independent suspension. It had 10" Pneumatic wheels in front to take the abuse and 8" Mecanums in the rear to reduce scrub and assist in maneuverability. It works pretty well, but if the mecanums are on the wrong sides, it made a huge difference, as the lateral forces of the wheels are fighting each other. I believe our students also programmed it as a standard tank drive, not mecanum drive. Mecanum drive doesn't seem like it would provide the correct directional commands to give you the driving you are looking for.
1: Change programming to tank drive, and test. 2: If that didn't fix the driving, flip your left and right mecanums. Last edited by NotBattleBots : 19-05-2016 at 08:56. |
#9
This design is not going to strafe, no matter how you turn the wheels, barring some unusual anisotropic coefficients of friction.
Placed on an approximately square base, this design would be marginally better at turning and marginally worse at driving directly forward than using omnis in the rear and using tank drive (that is, linking the front and rear wheels on each side). Without strafe capability, I don't see an advantage that justifies the two extra drive trains. |
#10
I have not tried it, but I would imagine it would behave better than traction and omni. Assuming the same rubber on omni and mecanum, it should have comparable COF and perform nearly identical forward, backwards. Turning should be better with mecanum - but more importantly, the resistance to being spun by a defender should be much better. In the past, we did not try this configuration given the size and weight (and cost) difference between omni and mecanum. Now, with the modern VEX mecanum, I believe it is worth another look. |
