Go to Post It is a good idea to try to stand in another person's shoes and treat them as your equal. It's called respect. - Jaine Perotti [more]
Unread 18-05-2016, 18:30
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Mecanum wheels on the front, regular wheels on the back
Need a little help here. This mini-robot has Mecanum wheels on the front and regular wheels on the back I know I've seen a discussion on how well/poor this would work, but I'm not finding it.
Appreciate either a link, or a quick comment on what you think of this drive.
(Ignore the details on the video, 3 of the 6 drives they built have the Mecanum wheels on the wrong way.)
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 18-05-2016, 18:46
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Mecanum wheels on the front, regular wheels on the back
They aren't powered, and the Instructable for the project actually calls them omni wheels.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 18-05-2016, 19:05
Right, but I'd like to power them and we all know that they really are not omni wheels. If they were, I've built a ton of robots with Omni<->regular wheels and I know how that works.
It's the combo of driving a 1/2 mecanum that I'm thinking about.
Unread 18-05-2016, 19:49
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Team SCREAM's 2014 bot had traction in the front mecananum in the back to help with turning. When I asked them about it they said they preferred it over omni wheels.
2016: FRC 865 Mentor
Unread 18-05-2016, 19:51
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Well, assuming you want to power all of the wheels, the forces generated by mecanum wheels has been discussed extensively. Similar analysis can be done for any combination and configuration of wheels.
For example, if using vector analysis on a 4-wheel partial mecanum drive:
-Two of the wheels can be modeled as described in the second linked pdf
-The other two will provide propulsive force only in the front-to-back direction. The 'only' side-to-side force will be friction, which will be whatever is needed to negate any forces acting on the wheel in that direction, up to the point where static friction is overcome.*
(*This is, of course, an approximation, YMMV)
Unread 18-05-2016, 20:05
Ernst's Avatar
Ernst
AKA: Ernst
http://www.chiefdelphi.com/media/photos/42399
Here's something from the 2015 offseason that might be helpful. 585 built a drivetrain with two front mecanums and a single, perpendicular, rear omni.
What do you want to accomplish with this layout? Or are you just wondering how it would behave?
Unread 18-05-2016, 20:29
I'm interested in how it would work. I put that wheel layout on a VEX square bot frame. I programmed it to be a regular Mecanum layout and it doesn't work well. Forward reverse works, but turning has the rear scrubbing.
The single rear omni is interesting since that would help the turning issues, and while moving forward the rollers would work well.
So with my little build failing with what could be the wrong code, I thought I'd try some math, hence the search here.
Unread 19-05-2016, 08:50
NotBattleBots's Avatar
NotBattleBots NotBattleBots is online now
AKA: C. Mathis
FRC #5132 (Roboclovers)
NotBattleBots is an unknown quantity at this point
5132's bot this year was a 4 wheel drivetrain with independent suspension. It had 10" Pneumatic wheels in front to take the abuse and 8" Mecanums in the rear to reduce scrub and assist in maneuverability. It works pretty well, but if the mecanums are on the wrong sides, it made a huge difference, as the lateral forces of the wheels are fighting each other. I believe our students also programmed it as a standard tank drive, not mecanum drive. Mecanum drive doesn't seem like it would provide the correct directional commands to give you the driving you are looking for.
1: Change programming to tank drive, and test.
2: If that didn't fix the driving, flip your left and right mecanums.
Unread 19-05-2016, 10:55
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
This design is not going to strafe, no matter how you turn the wheels, barring some unusual anisotropic coefficients of friction.
Placed on an approximately square base, this design would be marginally better at turning and marginally worse at driving directly forward than using omnis in the rear and using tank drive (that is, linking the front and rear wheels on each side).
Without strafe capability, I don't see an advantage that justifies the two extra drive trains.
Unread 19-05-2016, 15:46
AKA: Alan Wells
FRC #1350 (Rambots)
A tricycle layout might be interesting. you could drive the rear wheels and pivot on the front wheel. If you replaced the front wheel with a single swerve module, then you restore the holonomic drive capability. The fact that there are three points of contact eliminates the need for suspension in most cases.
Unread 07-06-2016, 09:10
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
I do agree that this chassis should be driven as tank drive - and that it can not strafe. The tank drive can (should) use one gearbox per side and as always all wheels should be driven.
I have not tried it, but I would imagine it would behave better than traction and omni. Assuming the same rubber on omni and mecanum, it should have comparable COF and perform nearly identical forward, backwards. Turning should be better with mecanum - but more importantly, the resistance to being spun by a defender should be much better. In the past, we did not try this configuration given the size and weight (and cost) difference between omni and mecanum. Now, with the modern VEX mecanum, I believe it is worth another look.
