Go to Post We should be celebrating every potential new science and technology leader regardless of which number is on his/her t-shirt. - Dmentor [more]
Unread 19-05-2016, 10:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Mecanum wheels on the front, regular wheels on the back
This design is not going to strafe, no matter how you turn the wheels, barring some unusual anisotropic coefficients of friction.
Placed on an approximately square base, this design would be marginally better at turning and marginally worse at driving directly forward than using omnis in the rear and using tank drive (that is, linking the front and rear wheels on each side).
Without strafe capability, I don't see an advantage that justifies the two extra drive trains.
