Go to Post I walk through the door, and suddenly the field breaks down. It must be my magnetic personality. - Swan217 [more]
Unread 08-04-2016, 18:42
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Our Hex Bore Encoder Hack
I thought that other teams might be interested in this hack:
When building our winch, we found that we needed to lose 1/2" of width in order to fit it in our scaler (a consequence of not modelling fasteners - ah well). To find the room, we moved the VEX encoder stage from the versaplanetary to the winch axle by printing a new "hex bore gear" for the encoder. The result worked so well we moved the encoder on our "battering ramp" too using the same trick (see attached photos).
You can find all of the CAD files you need to produce your own hex-bore encoders here. Feel free to use them, and share your results with us!
http://www.thingiverse.com/thing:1473056
Related story: maybe we're cursed, but we've had so much trouble with encoders over the years:
  • In 2014 (previous team) the plastic gears slipped in the (V1) shaft of the ballshifters. *Sigh*
  • In 2015 the rotor clamp kept slipping, and the cable kept popping out of the CUI AMT encoders. *Facepalm*
  • In 2016 we tried CIMcoders, but found they keep losing counts (despite several attempts to debug and repair - still don't know what the issue is). *Temper tantrum*
So after we got knocked out during quarters at Waterloo (congrats again 1241, 610 and 3560) we took the time to mount hex-bore encoders on our live axles (photo attached). We'll see at champs if they finally provide us with a rock solid drive encoder solution, and a chance to score in auto. (Now if only we could have talon data cables longer than 6"!)
ID:	20560  Click image for larger version
ID:	20561  Click image for larger version
Unread 19-05-2016, 13:13
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: Our Hex Bore Encoder Hack
I forgot to post an update to this story. The hex-bore versa encoders worked perfectly all the way through champs. They allowed us to implement our low-goal auto (https://www.youtube.com/watch?v=muoSbQza0zQ) which was key to our excellent performance in Carson. There are a couple of caveats though:
  • The versa planetary encoder housing is pretty flexible. It was a bit too easy to clamp it down in a way that pushed the internal magnet out of alignment. (Having a coloured light indicator for alignment was a big help though). Next year we might design and print a new housing, as well as the hex bore gear
  • The 6" ribbon cable limit really sucks. We built extension cables using breakout boards and pwm cables, but that makes for an expensive and time-consuming cable!
Otherwise I was pretty happy with these hacked encoders. They will be especially useful if we switch to a cantilevered live axle (west-coast drive) next year.
Unread 31-05-2016, 06:16
s5511's Avatar
s5511 s5511 is offline
FRC #5511
s5511 is an unknown quantity at this point
This sounds like an awesome idea!
Our team has recently been looking to use SRX Mag Encoders on Live Axles on our Drivetrain, too.
What material did you print the part out of?
NC Rookie All Star, Rookie Highest Seed 2015
NC THOR Winner 2015
NC Guilford County Winner and Creativity Award 2016
Unread 31-05-2016, 09:10
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Originally Posted by nuclearnerd View Post
[snip]
  • [snip]
http://www.chiefdelphi.com/forums/sh...d.php?t=142520
We used the connectors and cables linked in that thread to make our own SRX ribbon cables. They worked without issue all season.
Unread 23-07-2016, 23:46
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Hey all, Cable kit is now available...
http://www.ctr-electronics.com/talon...ription_tabbed
Unread 24-07-2016, 00:40
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
From the bottom of my heart, I thank you.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
