Go to Post It is a difficult balancing act - we're engineers because we like to solve problems, and to take a step back and let someone else solve it, with what may be a poorer solution, is darn hard. - DonRotolo [more]
Unread 19-05-2016, 14:49
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: Is Welding Worth It?
We outsourced the welding of our shooter together to a sponsor for the first time ever because rivets couldn't handle the stress of the ball being shot over and over again, leading to a weaker shooter. We riveted the gussets/metal together, then took it to our sponsor and they welded it for us, and we didn't have any problems. It was definitely worth it. If none of your team has had welding experience and is very confident, i would recommend taking it to get it welded.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 19-05-2016, 14:56
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Our team had been told to watch out for aluminum welding for it may give extra strength, but experience is needed and bolts and nuts can hold the frame together just as good. The only downside of that is be prepared to loose some bolts and nuts, but the pros are that you can detach parts in case repairs are needed.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 19-05-2016, 15:00
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not to mention that when you get to <0.100" material, the skill level required to weld aluminum goes way up. Nothing like burning a hole is the last weld, killing the entire piece to ruin your day.
If you have the resources, welding is great fun. If I had the resources in place (A good welder for aluminum is $1000+) it is a good resource. If you don't there areas that would get more bang for your buck. YMMV
Unread 19-05-2016, 15:13
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The first question that comes to my mind is what kind of rivets are you using? There are different grades and quality rivets. If you are buying them at your local hardware store in retail friendly packages chances are they are low strength. McMaster is one place that does sell high quality, high strength rivets also check for a local fastener supplier, Hi-Strength Bolt has locations in many areas.
I prefer rivets and/or nuts and bolts for the reason of quicker and easier repairs and changes.
Next time you are in traffic sitting next to a large truck take a look at the frame rail. You'll see that the cross-members and brackets are held on by rivets or nuts and bolts. That is so that those pieces can be replaced in the field in an expedient manner and without worry as to maintaining proper alignment or the skill of the welder and subsequent quality.
Unread 19-05-2016, 15:22
Golfer4646's Avatar
Golfer4646 Golfer4646 is offline
[SLFF]: The Breakfast Company
AKA: Nicholas L.
FRC #4646 (Team ASAP)
Team Role: Student
Golfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to behold
Every team is different, but my team has avoided having any welding on our robot at all. The reason being that should a weld break, we are (pretty much) guaranteed to not be able to fix it in the pit. We also have a sponsor that provides us with bolts for each year, as well as another sponsor that helps us with fabricated parts (usually laser cut and bent if needed), making a sheet metal chassis held together with gussets and bolts what we have found is the best option for us given our resources. We have also done drivetrains in the past made primarily from 1x2 aluminum, also held together with gussets and bolts.
Unread 19-05-2016, 15:26
Andy A. Andy A. is offline
Getting old
FRC #0095
95 welds were it seems to make sense, usually to reduce weight or to simplify a structure. It's not our first pick, but sometimes it solves a lot of problems. But we have a really good welder, and work in a welding training shop. Without those resources I don't think we could justify the time and risk of having welding done by a 3rd party.
We rarely use rivets, though. The basic frame elements are generally put together with screws and captive threaded inserts like rivnuts and pemnuts. We really like the easy serviceability screws give us at competition and during testing. There's also a comfort factor in the relative strength of machine screws.
Installing the inserts has a significant upfront investment in tools materials and time, and probably a measurable cumulative weight penalty. But I think it pays off over the course of a season.
Unread 19-05-2016, 15:40
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
Originally Posted by MrBasse View Post
Why do you grind your welds down? Are you looking for a smooth appearance or for a strong joint? In my opinion, nothing looks better than a smooth stack of weld material laid down just right especially on aluminum.
I don't really remember (that was over 5 years ago) but my guess is that it was either an aesthetic choice made by someone else or a "we need this surface to be flat" type of situation. Either way, I guess I was glad we did, as it caught the bad welds before they were a major problem.
Unread 19-05-2016, 15:59
FRC #1836 (MilkenKnights)
1836 hasn't welded for the past 4 years, and has been pretty happy. However, rivets, including those in highly stressed shear applications, can loosen up, creating a less than ideal joint (for comparison, we do use aluminum body aluminum mandrel rivets). It in the high load applications that we are considering welding joints as an addition to rivets and gussets.
Unread 19-05-2016, 16:42
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
As mentioned aluminum welds are typically not as strong as the aluminum itself. Welds can add material so they can add weight. Welds can embrittle material. Welds can cause oxidation. Welds can be deceptive.
Rivets and bolts add material and may be even more prone to do so. Rivets and bolt holes can weaken the material. Dissimilar materials can cause corrosion at the contact points.
All of those things aside - the design may specifically make one choice better than another. I can certainly see with the pits FRC uses that welding can be inconvenient if it fails. Then again maybe if it fails you just bolt or rivet at that point.
I don't think we have the welding equipment at Mount Olive High School anymore.
So if I want to cook some metal I have to do it at home, take it to a friend or take a trip to NextFAB.
Unread 19-05-2016, 17:07
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
If you have photos of where your rivets failed, please post them. That will make this discussion 1000% more beneficial to your team and other teams.
Your rivets failed most likely due to a poor design - either you're using rivets that are too small (we use 5/32", sometimes 3/16"), not using enough rivets, need a better gusset design, too high of stress to the affected area, etc.
We've used versa-construction with rivets and gussets for 3 years now and have been very pleased. It's simple, our students can build almost anything with it, and we've had no failures that weren't our own fault due to a poor design.
Buy a pneumatic rivet gun and a compressor if you can manage it - it will make your assembly go so much faster and we've found that they hold just as well if not better than ones done by a hand riveting tool.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 19-05-2016, 21:35
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Depends.
We use a MIG welder we received through a grant, we purchased a spool gun for it, and we teach a few of our kids to use it.
We normally use 1/4" aluminum plate for our drive train and weld the cross members into place. This year we also welded our shooter chassis (1/8" aluminum) together.
47 matches this year, not one broken weld.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 19-05-2016, 21:45
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Make good design decisions!!
Weld where it makes sense. Gusset and rivet where it makes sense. Bolt where it makes sense. Use wood and epoxy where it makes sense.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 19-05-2016, 22:14
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Being on a team that does not have welding, there have been many situations where I would want welding this year. 971's tube across their intake this year is a prime example of something that is difficult to do without welding. Of course there are ways to have the design not use that structure that necessitates welds, but the two-plate design for their intake is nice.
That being said I'm usually not impressed by student-made welds. I can't comment on how well actual welding holds up (only used it once in 2015), so don't ask me for execution stuff. Purely from a design standpoint, a lot of gimmicks are way easier to pull off with welds.
Unread 19-05-2016, 23:33
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is online now
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
$1000 is getting away cheap. And with GTAW (TIG) welders, a $1000 welder buys you very little in the way of an good amp control such as a pedal or thumb trigger. If you TIG weld without the amp control, it becomes even more an art to get little in avoiding edges turning down - it requires more table time that many teams cannot afford to offer in a short build season.
We recently purchased a Thermal Arc 161 after borrowing 5542's and it did the job. However, if you saw our 2016 robot, we also have a steel subassembly that carried most of the carnage that the Strongholds defenses mustered.
We also used rivets extensively and none broke - replaced, but never failed.
We will continue to use the GTAW process as it provides students a way to learn a new welding process - but it will never be a prominent process of joining for our robots.
Oh - and NDSU's Bison Robotics Greenhorns Robot was named Rivvet for a reason. It was completely assembled using rivets.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 19-05-2016, 23:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A high school student can absolutely learn to TIG weld proficiently with enough practice. In fact, my student's welds were hanging on Einstein, on 330's robot....
