Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 19-05-2016, 17:03
CMBrandon's Avatar
CMBrandon CMBrandon is offline
North America Marketing
Rookie Year: 2016
CMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond repute
Re: What Percent of Teams Use CAD?
All of the teams we work with use CAD systems. We have learned a lot from them about whats needed to make it run smoothly. The part some teams tend to forget is that your peripherals are just as important to the workflow as the program and knowledge base the user has. A good mouse/keyboard with certain features can make your life WAY easier. One of our teams uses some weird 3D knob thing that works great with solidworks. When used in conjunction with a Sentinel III mouse it can really speed things up.
http://www.cmstore-usa.com/robotics
20% Off Code: CMROBOT
Sponsored Teams: 4, 207, 294, 702, 599, 1868, 3476, 4481
Special Projects: 900, 2601, 4050, 4480, 5510
International Teams: 5883, 5996, 6008
DREAM Challenge
Check out LibbyK on twitch.tv
Unread 20-05-2016, 14:37
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
One of our mentors brought in something like this a while back for the team to use for CAD, one of our kids really likes using it; I personally found it bizarre and hard to CAD with, so to each their own I guess, I'll stick with my 3600dpi laser mouse.
Unread 20-05-2016, 15:15
Knufire Knufire is offline
I believe you guys are referring to this?
http://www.3dconnexion.com/products/spacemouse.html
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 20-05-2016, 15:31
cbale2000's Avatar
AKA: Chris Bale
Different version/brand in my case, but basically the same thing, yes.
Unread 20-05-2016, 15:43
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Once you use a 3D mouse, it is hard to go back. It just makes it so simple to rotate and see the side of the part that you need to see.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 20-05-2016, 16:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
3946 does not use CAD systematically.
We have CADded a few assemblies over the years, sometimes with solid works, and sometimes with power point. This year's wheel layout was determined based on "CAD" simulations of crossing the various terrain defenses in power point. Last year's adaptation of dura-omni to the KoP chassis was done in solid works before we built it. The ball pickup for Aerial Assist was laid out in power point.
Unread 20-05-2016, 19:15
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Power Point? as in microsoft PowerPoint?.... I'm guessing not
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 20-05-2016, 19:16
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Obvoiusly I could be totally wrong here, but I would guess that if a team is active enough to be engaged in Chief Delphi, than more likely than not, they will have a cad team.... just guessing
Unread 20-05-2016, 20:43
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of light
I was told that this is the first year the team hasn't done any significant CADing besides what was sent out to a local shop to be machined. You can probably guess what one of our summer projects is.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 21-05-2016, 12:39
pHolmgren's Avatar
pHolmgren pHolmgren is offline
AGM
AKA: Preston Holmgren
FRC #2557 (SOTABots)
pHolmgren has a spectacular aura aboutpHolmgren has a spectacular aura about
Our team just had a fully CADed robot and had our best season ever. I would recomend CADing for it helps plan out what can be done with limited space. At PNW district champs, we learned that there were only about 7 or 8 teams who CAD.
Autodesk Inventor is good.
Preston Holmgren
FRC 2557 SOTAbots
Unread 21-05-2016, 19:51
rlounds's Avatar
rlounds rlounds is offline
Registered Usr
AKA: Ryan Lounds
FRC #0865 (Warp7)
Team Role: Operator
Rookie Year: 2015
rlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to beholdrlounds is a splendid one to behold
Our team has done a full CAD of the robot in SolidWorks the past couple years
Head of Public Relations & Operator for FRC Team 865, Warp7
2016 GTR-C Quarter-Finalist (1310, 1325, 865)
2016 North Bay Regional Quarter-Finalist (2185, 4716, 865)
2016 Waterloo Regional Quarter-Finalist (2702, 5631, 865)
Unread 21-05-2016, 23:03
LCJ's Avatar
LCJ LCJ is offline
AKA: Lewis Jones
FRC #2468 (Team Appreciate)
Team Role: CAD
LCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really nice
My team, 2468, rigorously CADs every component of the robot to ensure smooth integration and communication between the design and manufacturing teams (which are distinctly separated on the team).
However, I know that some successful teams like Cryptonite (624) doesn't CAD their robot except for few parts that require CAM. They seem to do well every year anyway though... https://www.youtube.com/watch?v=adkAmveee6k
Unread 22-05-2016, 00:35
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
That seems a little low. How are you estimating that? Are you just counting teams that you know did a complete robot in CAD?
Unread 22-05-2016, 00:49
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
FRC 1640 uses CAD (SolidWorks). I believe most teams use CAD.
With the growth of 3-D Printing and CNC/CAM, it is almost indispensable.
From a real world standpoint, it is a tremendously powerful design tool.
But knowing how to CAD is not the same as knowing how to design. CAD's just a tool. Design in the intellectual exercise.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 22-05-2016, 00:56
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Can't speak for the person you're asking, but I remember being stunned at the number of teams at Championships who didn't use CAD or only used extremely limited amounts of CAD at the 2013 Championship. You can build some fantastic robots without even a little bit of it.
In Minnesota, significant use of CAD is extremely rare. Only a few teams I talked to have a reasonably complete model of their robot, and the vast majority used it to model maybe a couple of parts.
Personally, while I personally love CAD, and would never design a robot without it, I don't push it. CAD is something you can only really do effectively if you have students/mentors/et cetera who want to do CAD. It takes a significant time investment to become competent, so the best way I've found to get people/teams interested in CAD is to get them excited about performing well and doing well at competition. A little bit of competitive spirit goes a long way.
Edit, to answer the OP:
I'll speak for the teams I have first-hand knowledge of:
2220, while I was on it (11-14), was pretty solid on getting a reasonably complete CAD model when I was on the team. Of course, most of that work ended up being me, but I believe the last couple years they've had a reasonably complete model. When I was on the team it was Creo or Pro/E, with a little bit of Solidworks, Inventor, or AutoCAD for students or mentors who preferred that. Now I believe they're almost entirely Solidworks, but you'd have to ask someone who is currently on the team about that.
2667 had no students doing CAD any of the years I worked with them. I maintained a personal model to check dimensions and explain concepts, but none of the students contributed to that model. This was due to a variety of reasons, but ultimately it worked out decently and now there are some students who are really pushing CAD for next year. I used Creo, they'll probably use Inventor.
9205 (FTC) does a CAD model of everything other than physically correct chain. I've worked with a couple of the students over the past two years to build up enough knowledge that they could probably design a reasonably complete robot in Creo without much or any input from me. This means I get to help with different things
Finally, 'Snow Problem (Ri3D) keeps a reasonably complete mechanical CAD model throughout the three days. It's almost all me on that, with a bit of Evan and Ryan contributing, particularly with 3D printing stuff. That's almost all Creo, with a bit of Solidworks for Evan.
I'm pretty sure the heavy CAD use on 3/4 of my teams is the exception, not the norm.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
