Go to Post Of course this should be your decision- not the FIRST community's. Take charge of your destiny. - Wayne C. [more]
Unread 18-05-2016, 19:02
catmanjake catmanjake is offline
FRC #4009
catmanjake is an unknown quantity at this point
Orange Robot Safety Light
All,
Where can you order the Orange Robot Safety light from?
Thanks.
Unread 18-05-2016, 19:14
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: Orange Robot Safety Light
I believe the RSL is the Allen-Bradley 855PB-B12ME522 according to an old Reddit thread which should help you, but I do not know a great place to get it.
https://www.reddit.com/r/FRC/comment...ght_cost_help/
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
I found them here for the low low price of $121.50/ea (thank goodness I'm not in marketing):
http://www.plccenter.com/Buy/Allen%2.../855PBB12ME522
*link is from the same Reddit thread as above.
Nate
Unread 18-05-2016, 19:22
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
A robot safety light(RSL) is included in the Kit of parts most years, if this if for an off-season robot or to replace a broken one etc. you'd probably be best asking teams near you if you can borrow one. Most teams probably have lots of unused/spare lights.
Unread 19-05-2016, 02:40
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
If this is for a competition, then one should be in the kit of parts, or you can ask around other teams.
For off-season events and demos, you can get away with any 12VDC orange, non-flashing hazard/indicator light (eg https://www.superbrightleds.com/more...nnector/1085/). We've grabbed them from local auto stores and haven't had a problem.
The only potential issue you may have is the current draw being too high, but with LEDs that would be surprising. (BTW, haven't used the one in the link, but don't see why it wouldn't work)
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 19-05-2016, 09:35
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
If you need one for/at state, I can have 2855 bring an extra.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 19-05-2016, 10:12
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Anyone use two on their robot? I know a few tall robots this year used two.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 19-05-2016, 10:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We used two on our robot for the first time this year. Not because we were tall, but because we were short. The only decent place we could put the light was easily visible from the front, back, and one side, but not the other. We used a signal light from a previous year. We just wired them in parallel from the RSL output on the RIO.
Unread 19-05-2016, 17:45
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
We used 2 due to the fact that we couldn't see the one from behind. We wired the second one into the first one and that has worked just fine.
2. Wire the robot
7. Be active on CD
Unread 19-05-2016, 18:11
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
HOW MUCH?! For an LED???
If two of the "regulation" lights ran off one port on the Rio, I see no way a normal LED could draw too much current, unless there's a big wiring fault...
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 19-05-2016, 21:23
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
I ran into this with my personal robots.
I used to have a place I could get these for $30.
No longer have that option.
Bought the yellow LED replacement for the 2 element car blinker and the surface mount socket. Put a terminal strip on the 3 wires all that cost $20 with some shipping.
Been meaning to 3D print a similar base and use a plastic shot glass to make a similar assembly.
Unread 19-05-2016, 22:08
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
PLC Center is not an official distributor for AB products and pretty much sells them at whatever price they can. I've seen them sell stuff for 80% of list cost and 300% above, depending on the condition and if it is obsolete. Generally you can't price many industrial automation components online since the big players (Allen Bradley, Siemens, etc.) only sell through sales reps.
This is the official catalog page for the light, about halfway down the page (it comes in 6 different color and 3 different sizes!). You can search for your local distributor here, it looks like Mielke Electric is the AB distributor for the Duluth area.
