Go to Post The world isn't made out of Nerf, you will get scrapes and bruses, but you will get back up and continue on. If you watch out you can avoid the sharp edges. - Joe Matt [more]
Unread 19-05-2016, 20:27
DevinTJRobotics DevinTJRobotics is offline
FRC #3648 (Sparta Robotica)
Team Role: Electrical
DevinTJRobotics is an unknown quantity at this point
roboRIO, Radio, and Connection Trouble
I am having trouble with getting Driver Station to communicate with the roboRIO. Here are all the details. I can connect to the radio just fine from the laptop and when we go to put the code on the roboRIO the COMM LED is green and all looks good. However Driver Station is still getting nothing in terms of communication and code regardless of if we reboot the roboRIO. Pressing reset on the roboRIO also doesn't help as all that happens is that the COMM LED turns red and the roboRIO has no code to run off of. In addition there is a problem where three of the seven CAN Talon SRX's that are connected don't appear on the screen when we go into Internet Explorer and access the robot through Silverlight. Any help you can offer would be greatly appreciated.
Thanks
Unread 19-05-2016, 21:03
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: roboRIO, Radio, and Connection Trouble
Are you using the right version of the driver station? Try disconnecting the Talons that aren't working and connecting without them. I think a static IP address could affect it, but I'm not sure how to fix that. If it still doesn't work, try connecting with only the basic stuff connected(RoboRIO, radio, whatever else you need to only connect) and slowly add more back in from there.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 19-05-2016, 21:26
ATannahill ATannahill is offline
AKA: Alex Tannahill
I think you might have a few different issues occurring at the same time. I cannot tell exactly, I want to get a picture of what is happening but right now it looks like a Picasso. The easiest way to help you is if you give me a detailed step by step of what you do, including how you are connected to the roboRIO (usb or ethernet), what you do, what the DS shows and what the lights on the roboRIO shows.
First, to get connection on the driver station it sounds like your you might have a firewall active. Make sure to shut down windows firewall, windows defender and any third party fire walls (mcafee or norton). How do you know that you can connect to the radio if the DS is getting nothing?
Do you have all the talons on CAN with yellow to yellow and green to green? I expect you do but I don't want to have you try other things if the fix is something simple. If so, where are they on the line of CAN items?
- Arizona North
