Go to Post The answer doesn't lie with an all student run team, or an Engineer-fest team... But somewhere in the middle. Moderation is key. - Cody Carey [more]
Unread 19-05-2016, 22:37
happyWobot happyWobot is offline
FRC #0122
happyWobot is on a distinguished road
Re: Weird Gearbox Sound
Originally Posted by maxnz View Post
So, we had a little parade through the school this morning where we ran the robot, and the robot seemed fine. The stuttered movement never happened, so we think that that was due to the low battery.
As for the gearbox, it still had the weird sound like there was sand or something in the gearbox. The other gearbox sounded similar this morning. It ran fine, but we don't know what the sound is from.
You said this was a TB Mini, correct? Back out the screws holding the plastic cover in place about 1/4 turn each. Run the robot and see if that changes anything. If not back them out another 1/4 turn. I ran into a situation this year with a brand new mini that if I over tightened the case the transmission would make noise. I think something is at a very low clearance and that the plastic cover changes shape if overtightened causing it to come in contact with one of the gears. Any chance your mini is 12.75:1?
Unread 19-05-2016, 22:41
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Yup, a Toughbox Mini. It is set at the standard gear reduction that is detailed in the assembly manual. If I remember correctly, it is 12.75:1 or something similar. We can try that tomorrow when we unbag the robot at state. Did it sound similar to what it sounded like in the video I posted?
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 19-05-2016, 23:21
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
If you are still experiencing these sounds, I would definitely take the gearboxes off and double check the gears. It's highly unlikely that you have managed to sheer teeth off the steel gears in the TB Mini, but this is the year of the strange failures.
A couple of quick questions:
Did you run the gearboxes in for about 30 minutes prior to greasing them?
Have you done any maintenance on the gearboxes this season?
-Running outside might have introduced a foreign contaminant into the gearbox, and it might be worth cleaning the gearboxes out and greasing them again after checking the teeth.
Have you checked the tightness of the screws holding the CIM motors on?
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 19-05-2016, 23:38
FRC #0122
If you mean the sound at the end of the video, yes, that sounds familiar.
Has it always made the noise since the case was constructed?
If not, is there any chance some students went on a bolt tightening exercise recently?
Did you tape over the small holes on the back side to prevent debris from getting in?
I experienced the noise with a brand new case. Took it apart and reconstructed it twice. Discovered that if I tightened the plastic cover too much the noise was louder. I had a second case that was also brand new purchased at the same time. It made not a sound. Both were constructed at the same time, in tandem, and were identical as best as I could observe. I let off on the case bolts just till the noise was barely noticeable, then installed it CIMs and all into the chassis.
It actually got quieter over time. I had several theories about what it was, first was that the tightening of the case was causing the plastic to deform in a way that made it come in contact with one of the gears. The second was that the weight of the CIMS were doing something similar to the plastic cover. The third thing was that if there was some sort of contact or vibration, that the plastic cover was magnifying the sound like a drum.
I know for certain it was not the gears. The gears were clean with freshly applied grease. With the cover off it did not make a peep when turned. The gearing is ridiculously simple, the shafts confirmed to be mounted into the bearings until firmly seated. With the cover on, once tightened all the way down, it would make that rattle. Like as if gear teeth were coming contact with some part of the cover.
If you find that the noise goes away by loosening the cover just a bit, tighten it back down until the noise starts again and then just back off a touch. We got through two qualifiers, a district Championship and worlds and never once had an issue with either one.
Unread 20-05-2016, 08:30
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
As far as I know, it only started making that sound on Saturday. They both sounded like the first sound until then. We did tighten bolts last week, but they were the ones holding the plate to the chassis. The other gearbox sounded similar to the weird one yesterday morning, but not as 'bad'.
Also, what holes are you speaking of?
As for greasing, the gears already had some grease on them from previous years, so we didn't think much about regreasing them. We did take apart the gearbox in question at our regional because a key fell out (making one of the motors hot, indicating something was wrong). We took it apart, added a key, added a washer (to each CIM) to keep the keys in, then reassembled it and added it back onto the robot.
2. Wire the robot
7. Be active on CD
Unread 20-05-2016, 09:04
n.e.r.d #6
I would definitely pop open the gearboxes and give them a good once over, clean the gears off and the housings out, and then reapply some red tacky grease. There are a few holes on the outside of the housing that allow you to tighten the screws down, etc. Those holes do have the risk of debris entering, although it is rare that it is enough to cause more extreme sounds like those in the video.
AndyMark, Inc.
Unread 20-05-2016, 09:13
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
So, a few thoughts based on experience:
  1. The first part of the video seemed like an electrical issue, like a dead battery or a short. The behavior was not indicative of a mechanical failure, at least none I've seen.
  2. The sounds in the second part sounds like one of three things, it could be either one of the motors not being powered (assuming you use 2 per gearbox), a CIM that has lost it's key between the shaft and the pinion gear (and is free-spinning), or gears not engaging each other in the gearbox for some reason (probably due to lost teeth or loose motors).
I would be curious if the issue persists if the robot is up on blocks (wheels not touching anything), I would also be curious if you could identify a certain action that causes the issue to happen consistently (turning the robot, for example) or if it just happens at random. I would also suggest monitoring battery voltage during such tests through the driver station.
On a somewhat related note, our team experienced some odd behavior (seemingly random jerkiness during acceleration) with our drive system this year when using Talon SRX controllers in CAN configuration. We later realized the issue only occurred when the controllers were fed a 100% power command. We changed the code to limit the max output to 99.9999% power and the issue vanished.
Unread 20-05-2016, 09:32
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
The first part was the battery. It hasn't done that when we used it with a full battery since then.
When we recorded those sounds, we were lifting up each side individually and ran them, first the left (first sound), then the right (second sound).
I'll make sure that we (I) clean out and regrease the gearboxes tonight. I'll also check the CIM motors to see if they still have their keys. What do you recommend to clean the parts with (paper towels, something else)?
2. Wire the robot
7. Be active on CD
Unread 20-05-2016, 09:58
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Let me know once you get your pit set up and are ready to look at this, I can help you figure it out
If the grease does need to be replaced, wiping everything down with paper towels is good enough - you don't need to go to too many extremes in getting the old grease off!
2016: Lake Superior WFFA
Unread 20-05-2016, 10:04
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
If I have my way, we'll probably start looking at it once we get approval to unbag, before the pit is completely set up if possible.
2. Wire the robot
7. Be active on CD
Unread 20-05-2016, 10:26
Well, in that case make sure your lock up form us with your robot when you walk through the door - we'll be checking them before you even get to your pit!
Unread 20-05-2016, 10:54
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
Will do
2. Wire the robot
7. Be active on CD
Unread 20-05-2016, 16:32
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
It kind of looks to me like nothing more than a brown-out. The stuttering and flickery RSL are the normal symptoms of brownout, and a difference in gearbox sound (because you aren't giving the motors your normal 11-13 volts) is expected. If your battery read as 39% (3.9V?) then you were probably well below brownout levels.
The fact that no one else mentioned this has me worried that I missed something obvious though
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 21-05-2016, 07:10
Several people's first guess in the thread was dead battery, which is one way to cause a brown out. As there can be other root causes for brown outs, knowing that it was caused by a dead battery is a more precise (and more easily fixable) analysis.
Unread 21-05-2016, 21:53
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
So today, we did an amazing job at our first ever state championship tournament (13th/30). The gearboxes worked fine. We actually have thought that maybe it has sounded like that the whole time, yet we never could hear it in our shop or at the regional.
2. Wire the robot
7. Be active on CD
