Go to Post For example an iron block is very simple and very robust. Strap a control system on it and it will meet the requirements of being a FIRST robot. However, it sure doesn't do very much, nor is it innovative. - sanddrag [more]
Unread 19-05-2016, 23:54
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Bicycle Drive?
Bicycle drive would consist of a swerve module in the front and a free-spinning traction wheel in the back, with the CoG perfect centered on the line connecting the two wheel axles. It would drive like a bicycle.
This seems easy enough to build for some team with a spare swerve module. Has this been done before? If so, anyone have some video of it?
Of course, bicycle drive would be useless for a real competition since it tips far too easily and require constant movement to stay upright. Seems like a fun offseason project though, especially on the software side with auto-balancing code.
Unread 20-05-2016, 00:07
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Bicycle Drive?
How would code balance a robot with one wheel in front of the other?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 20-05-2016, 00:22
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Bicycle Drive?
I don't know for sure, but I think that, using gyros to determine if and how the robot is tipping, you could program it to turn into the direction it is tipping. With a good code and a well balanced robot you could theoretically drive relatively steady with this configuration.
Unread 20-05-2016, 00:27
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Bicycle Drive?
Why not just take a bicycle and attach a servo or VP to the handlebars via a sprocket or gear? Then you just need the gyro and encoder, no swerve modules or anything necessary.
Unread 20-05-2016, 00:39
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: Bicycle Drive?
Check the 2008 robot from 1318 Issaquah Robotics Society. They called it the "Killer Rabbit". It was a lap runner following the same strategy 148 used with Tumbleweed. There is some video of it on The Blue Alliance. As I recall, it struggled with falling over during the first regional they entered, but by the 2nd regional they performed well enough to rank #2. I think it ended up with outriggers to keep the wheels on the carpet when it would tip so it could recover.
Unread 20-05-2016, 01:02
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Bicycle Drive?
An autonomous motorcycle was entered into the first? DARPA autonomous vehicle "grand" challenge (The first of the two (the off-road one) challenges held a few years ago that were intended to give the autonomous ground vehicle industry a big boost).
A little internet searching should turn up info about their methods, and about the general topic.
