Go to Post I have no clue. All I know is that every year the riddle in the clue has confused me but this year it is the lack of confusion that confuses me. - hallk [more]
Unread 20-05-2016, 11:43
jgerstein jgerstein is offline
FRC #1257 (Parallel Universe)
jgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to behold
Re: What can FIRST do to increase FRC team sustainability?
Originally Posted by Ian Curtis View Post
What years are FRC teams most likely to fail? I would guess something like years 2 & 5, but I'd love to know the actual answer. Can someone generate those numbers real quick?
I was curious about this too, so I pulled some data from TBA. A few teams show up a year or two before their rookie year because of off-seasons, but not enough to have a major effect on the numbers.
The last two tabs are the raw data I pulled from TBA and an expanded table showing which years each team was active in.
Team Survival
Sheet 1 (% of active teams by rookie year): Each row represents a rookie year (there were no 1993 rookies, so I left 1993 out). Each column is a year from 1992 through 2016. Each cell contains the percent of teams from that rookie year that were active in the given year. For example: Cell V12 indicates that in 2011, 45% of the teams that were founded in 2004 were still active.
Sheet 2 (# of active teams by rookie year): Each row represents a rookie year (there were no 1993 rookies, so I left 1993 out). Each column is a year from 1992 through 2016. Each cell contains the number of teams from that rookie year that were active in the given year. For example: Cell V12 indicates that in 2011, 75 of the 403 teams that were founded in 2004 were still active.
The other sheets are not particularly useful for looking at directly.
Last edited by jgerstein : 20-05-2016 at 12:28. Reason: Added a little more info about the spreadsheet
Unread 20-05-2016, 12:11
rwodonnell rwodonnell is offline
AKA: Rick O'Donnell
FRC #2876 (Devilbotz)
rwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to behold
Team Survival
This is great, thank you! (How do I read it?)
By the way, if I understood how to give the little green dots, I would give you some for this...
Unread 20-05-2016, 12:27
I'm glad I can help!
Thank you! If you do want to, there is a scale icon next to the post number where you can do that.
Unread 20-05-2016, 12:47
AKA: Rick O'Donnell
Thanks for the explanation on the google sheet. I hope you don't mind, but I created a copy of the sheet and added a column in the "raw data" tab with this formula:
=if(D2 <> 2016, E2, "")
What I wanted to see was, for teams that were not active in 2016, how many years were they active.
Here's the histogram of that:
Unread 20-05-2016, 12:55
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Srsly? 600 teams have dropped out after 2 years?
Unread 20-05-2016, 13:01
AKA: Rick O'Donnell
The number was 599, but when you add in the 169 that dropped after 1 year, then you have 768 teams that lasted 2 years or less. When you add in years three (459) and four (304) dropouts, you have 1531 teams that have lasted only through one cycle of high school kids. That's roughly a quarter of all teams ever created.
Unread 21-05-2016, 07:09
adammiller3122's Avatar
adammiller3122 adammiller3122 is online now
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Just click on the "balance" icon in the top right corner of the post.
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
Unread 20-05-2016, 21:29
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Team Survival
Hope no one minds, but I took the liberty of making a copy of that spreadsheet and adding a few more tabs to compare rates of team loss, as well as some graphs for showing team retention by team age. Thought the results were interesting, so I figured I'd share it...
https://docs.google.com/spreadsheets/d/15ys5j6c2QXwaIhTeKTSLQ5TfnfIJy1ee-8FHf0RXUS4/edit?usp=sharing
Sheet Tabs underlined in Green are either new or have new content in them.
