Go to Post After all FIRST & CD are both places to learn everything. - popnbrown [more]
  #46   Spotlight this post!
Unread 20-05-2016, 19:02
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Is Welding Worth It?
No one has mentioned brazing aluminum:
http://muggyweld.com/super-alloy-5
  #47   Spotlight this post!
Unread 20-05-2016, 19:12
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by InFlight View Post
On your riveted joints failing. It's very important to use the correct grip length and hole size for the rivets. If your riveted joints are failing constantly, it's likely some sort of installation error.
Welding Aluminum requires either a MIG or TIG welder. This requires some considerable practice, and mentor familiar enough with the equipment to teach others how to use it safety. It can only be used with some types of Aluminum, stick with 6061.
While not as strong as a weld, it is also possible to braze Aluminum with a plumbing torch. I'd only try this with 6061 aluminum and use Bernzomatic AL3, Alumaloy, or Durafix braze rods.
  #48   Spotlight this post!
Unread 20-05-2016, 20:21
techhelpbb's Avatar
Originally Posted by JamesCH95 View Post
Well they did not mention MuggyWeld.
So I think you could have snark lite on that but point taken.
  #49   Spotlight this post!
Unread 20-05-2016, 21:42
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Brazing Aluminum is best done with a specialized Flux first to reduce the oxidation layer and help the braze to flow. There are quite a few different Aluminum braze rods out there. I just mentioned some.
Using a rod with flux in it is fine, but is a poor subistute for applying AL flux first. The Benzomatic AL3 rods are available at Home Depot stores, and are thus the easiest to find for most with no shipping.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
  #50   Spotlight this post!
Unread 20-05-2016, 21:55
cpiravi's Avatar
cpiravi cpiravi is offline
FRC #3476
cpiravi has a spectacular aura aboutcpiravi has a spectacular aura about
Welding is totally worth it in my opinion. I have welded for my team for the past 3 years, and it takes a lot of practice and patience to get to a place where you can weld for your teams robot. It took my team mate and I a whole summer of practice to be good enough to weld our robot. This year, while I welded our competition bot I was training new students by having them weld our practice bot, so they are ready for next season. The many pros and cons robot wise have allready been said in this thread, and I also think it's a great thing for students to add to their resume, and a good skill to have. I know my teammate and I (and I'm sure many other students) have been given job offers and scholarships because we can weld. If a team can afford a welder and has someone to teach students how to weld, I think the pros definetly outweigh the cons.
Team 3476 Code Orange, Student 2013-2016
  #51   Spotlight this post!
Unread 20-05-2016, 22:02
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Do you have any comments about brazing versus welding AL? This looks like a really viable option for low-resource teams.
  #52   Spotlight this post!
Unread 20-05-2016, 23:00
InFlight's Avatar
AKA: Jim
I generally prefer riveted construction when practicable for frames. Otherwise bolted fasteners. Even with experienced teams, you'll have much more consistent build quality that way.
We did weld some steel bumper attachments this year. We've used some welded structure in the past as well. Welding is a useful capability, but it takes a lot of practice to make good welds.
There are some situations such as a swerve drive pivot tube that welding or brazing simplifies the construction details.
I've brazed repaired aluminum automotive parts. It similar to brazing copper plumbing, it's much easier skill to learn then good TIG welding.
  #53   Spotlight this post!
Unread 20-05-2016, 23:39
jeremylee's Avatar
jeremylee jeremylee is online now
FRC #1736 (Robot Casserole)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We had problems in past with riveted joints coming loose over time. We have since switched to Avex 1661 series rivets in 5/32 and 3/16 sizes with proper sized drill bits that we keep stored in our rivet box. The 1661 series seem to be more forgiving related to misalignment and pull the material together very tight before snapping maintaining strong joints throughout the season. We didn't have any issues all year with our rivetted VersaChassis and we will likely use the same approach going forward.
However, if we had the ability to weld, we'd likely utiize it to simplify our construction in key areas of the robot.
  #54   Spotlight this post!
Unread 21-05-2016, 12:33
pHolmgren's Avatar
pHolmgren pHolmgren is offline
AGM
AKA: Preston Holmgren
FRC #2557 (SOTABots)
pHolmgren has a spectacular aura aboutpHolmgren has a spectacular aura about
We've welded our robot for the past 2 years. When you design before you weld, it works out very well. We use aluminum TIG welds.
I would say yes, welding is very much worth it.
Preston Holmgren
FRC 2557 SOTAbots
  #55   Spotlight this post!
Unread 22-05-2016, 16:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Tom Line View Post
As an afterthought.... look at some of the critical joints on 254's robot. They are both welded, and riveted.
They are generally only riveted to serve as fixturing for the welder, so that no hand alignment is necessary. Since we've started doing that we've gotten huge increases in quality and reduction in time it takes for the welding to be completed.
2001-2004: Team 100
2006-Present: Team 254
  #56   Spotlight this post!
Unread 22-05-2016, 20:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Interesting lesson learned. Maybe we will put it into practice too.
  #57   Spotlight this post!
Unread 23-05-2016, 16:34
kevincrispie's Avatar
kevincrispie kevincrispie is offline
FRC #0971 (Spartan Robotics)
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
Can't recommend this enough. 971 also generally rivets together assemblies before welding. It allows us to fixture the assembly the way we want before its welded, which makes it much easier for the welder, much easier to transport to the welder's shop, and helps eliminate inconsistencies due to the welding process. We have seem much better results with pre-riveted welded assemblies.
"If you want to build robots, you're going to have to break a few small appliances"
  #58   Spotlight this post!
Unread 23-05-2016, 17:03
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
192 also rivets before welding many of the parts.
KF6UZX
  #59   Spotlight this post!
Unread 23-05-2016, 21:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Add 696 in there for one more ditto.
  #60   Spotlight this post!
Unread 25-05-2016, 17:43
Spark Spark is offline
FRC #5931
Spark is an unknown quantity at this point
As mentioned aluminum welds are typically not as strong as the aluminum itself. Welds can add material so they can add weight. Welds can embrittle material. Welds can cause oxidation. Welds can be deceptive.
Just adding that although welds do weaken metal you have to keep in mind that drilling lots of holes in a piece of metal for rivets or bolts can weaken it as well. Welds, if done RIGHT are the strongest option, but rivets and bolts are faster.
