Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 21-05-2016, 09:47
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: Lathe Suggestions
Machining 1/2 inch hex shaft can be done on a mini-lathe.
For general FRC use something around a 10 x 40 with a BXA tool post size is ideal. Having a quick change tool post speeds up the work. Watch the motor specs, you need a motor that will work with your existing power outlets.
You'll want to save some of your budget to buy a good assortment of cutting tools, cutoff blade, grooving tools for c-clips/e-clips. Also a full tap and drill set.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
