Go to Post Is that severed hand legal? I think it's a COTS assembly from previous years. - Taylor [more]
Unread 21-05-2016, 14:46
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
Re: Off season T-Shirt Launching Tank Robot
Almost done!
Here's a short video of our shooting test on the robot. Still have to get some code on the robot to run it. The turret is also on backwards but we're too lazy to run some code to turn it around haha.
https://www.youtube.com/watch?v=vC1d51Z6fuY
Now we just have to finish the pneumatics, loading mechanism, 3D print a ton of wheels, and finish the drive train.
Some more pictures: https://imgur.com/a/iF3vY
This is safe... right?
Unread 23-05-2016, 08:19
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by juju_beans View Post
Almost done!
Two questions:
  1. What type of storage tank are you using for your accumulator, what pressure does it operate at, and where did you get it from?
  2. What type of hose are you using between the accumulator and the cannon?
It's looking great so far, can't wait to see the finished product!
Unread 24-05-2016, 14:15
nirmatt_1690 nirmatt_1690 is online now
FRC #1690
nirmatt_1690 is an unknown quantity at this point
Almost done!
looking great!
what is the max firing rate?
Unread 25-05-2016, 00:29
juju_beans's Avatar
Rookie Year: 2016
Originally Posted by cbale2000 View Post
Two questions:
1. The shooting tank is a metal storage tank that operates at anywhere from about 70 psi if we're low on air to 110 when we're full on air. It is rated of 220 psi I think. The big black tank is just another metal tank that holds 120 psi and slowly feeds into the shooting tank. Not actually sure where we got either from sorry!
2. 3/4 inch pvc hose. It is rated for up to 120 I'm pretty sure.
Originally Posted by nirmatt_1690 View Post
looking great!
Right now the magazine isn't done so we don't really know the firing rate, but it should be fairly fast as after it shoots it just unlocks the shell, ejects the shell, then lets the next shell fall down and finally seals the shell and it is ready to shoot.
Unread 03-06-2016, 17:10
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
As an Ex-3647 student... i remember that tank...
The smaller grey tank was obtained from McMaster-Carr and is stupidly heavy/overbuilt for FRC competition uses (like 300+ PSI).
The bigger black one looks like it's an off-road compressor tank used by off-roaders for air reserves. IE http://www.walmart.com/ip/42279947?w...590128&veh=sem
We have used the later on 2485 to good success.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 03-06-2016, 17:41
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
The smaller tank was the one I was interested in because of the large output port, almost every other tank I've found has much smaller (1/8" typically) ports which makes adapting to a 1" sprinkler valve (or non-plastic functional equivalent) much harder.
EDIT: Is this similar to what you have? http://www.mcmaster.com/#9908K19
