Go to Post FIRST is different... we commute, journey, and make pilgramage to attend our events. Something that is expensive and exclusive. - Erin Rapacki [more]
Unread 22-05-2016, 13:41
Richard100 Richard100 is offline
FRC #0836 (RoboBees)
Richard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to behold
Re: NavX MXP Continuous Angle to Calculate Derivative
Look at the Endnote at the bottom of the last page.
The Endnote LV code you reference is functionally equivalent to shortest_angle = (present-previous) - 360*floor(0.5+(present-previous)/360); provided here ...
If your language does not support IEEERemainder, you can use this one-line function instead:
Both can be written in LV by building up the function from other primitive programming functions (as you depict in the endnote image).
What I wanted to know was whether LabVIEW has IEEERemainder as a programming function (call it Rem). There is a Mod (%) function (known in LV as Quotient & Remainder), but of course Rem and Mod differ in how they internally round, which is what makes Rem useful here.
Same question as you asked here, only for the LabVIEW language. Equivalent to asking: Can it be done in LabVIEW "... with one line of code".
Any LabVIEW experts know? If not, might this be in the development pipeline?
Unread 22-05-2016, 15:53
You don't need an accumulator when using a gyro if all you care about is your heading.
Not finding this to be very clear either. We're likely discussing different aspects of the problem.
It's not clear what you're saying here.
Ok. The OP's framing of the problem:
Originally Posted by lethc View Post
Currently both getAngle() and getYaw() are not continuous, and their ranges are [0, 360] and [-180, 180] respectively, so at the point where the robot crosses the threshold of a range the values jump ~360 degrees ...
Does anyone have any ideas on how I would get a continuous angle heading ...?
Proposed solution:
what you want is the shortest angle from the previous reading to the present reading, with the correct sign. The IEEERemainder function1 does this with one line of code:
shortest_angle = IEEERemainder(present-previous,360);
C# and Java both support IEEERemainder.
Proposed solution amendment:
Originally Posted by Richard100 View Post
Note that if one is streaming readings from an angular position sensor (such as a gyro or IMU), one would need to add an accumulator to this shortest_angle function to continually maintain angular position.
If the OP streamed a series of sensor readings, range constrained as [0,360], into a function
the resulting output would need to be accumulated to maintain position. Say robot yaw initializes at 0 degrees, moves clockwise over time to 15 degrees, then counter-clockwise to 350 degrees, as reported by the range constrained sensor. Consider:
Iteration       Previous        Present         Pres-Prev       Function       Accum
1		0		0	        0               0              0
2	        0               5	        5               5	       5
3	        5	        10	        5	        5	       10
4	        10	        15	        5	        5	       15
5	        15	        10	       -5	       -5	       10
6	        10	        350	        340	       -20	      -10
Rather than using what the OP started with, a Present value exhibiting the range-constrained discontinuity, it sounds like the OP needs the accumulated function result.
I'm interpreting the OPs desire for a function that converts his range-constrained sensor output to a non-range-constrained one. Your IEEERemainder function, with an accumulator, accomplishes this.
Unread 22-05-2016, 16:35
I am discussing the solution to this aspect of the OP's original framing of the problem (see bolded portion):
Does anyone have any ideas on how I would get a continuous angle heading from the NavX? I.E. one that doesn't jump from 360 to 0 instantly, because that messes up the derivative calculation
You don't need a continuous angle to do a simple difference calculation (which is what I anticipated the OP was really wanting).
The IEEERemainder gives you that answer:
Just tried this out and it works perfectly. Thank you for your help.
Unread 22-05-2016, 19:50
Thanks for taking time to walk through this! The distinction you reference clears up the differing perspectives / solution space.
Unread 22-05-2016, 20:25
You can do a "line of code" in LabVIEW by putting it in a Formula Node. It's exactly like writing an expression in C.
Unread 12-06-2016, 12:29
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Labview Subvi implementation of this attached.
Tested with the data set published, and checked results.
Sorry, not a LV guru, so did not take the time create input matrix and results.
(started too, but I knew there was a much simpler way than the way I was doing it.)
Thanks, we struggled with the gyro rollover in the past and this implementation seems to solve all of the issues we have tried to conditionally fix in the past.
Thanks Ether.
The sooner we get behind schedule, the more time we have to catch up.
