Re: Lathe Suggestions
I would definitely recommend buying the largest lathe you can afford. An old used lathe (hardinge, monarch, hendey) will be better than a modern machine but can be harder to find.
http://www.grizzly.com/products/12-x...campaign=zPage these seem to be pretty good for the price and size. |
Other than HASS, there are no domestic lathes in production. The current South Bend ones are all imports. If you have limited shop space; a Bench Top to unit would be the way to go. Otherwise their are a lot of "tool room" sized lathes in the used market. Last edited by InFlight : 23-05-2016 at 13:22. |
Standard Modern makes lathes in Canada, which afaik is the only North American lathe still in regular production. They are not cheap though. I got a quote last fall just to see and a 1340 was $16,000 and a 1640 was $27,000. |
Smaller lathes are cheaper, however smaller sizes can be killers on precision. If your doing non-critical shapes then small lathes are good but if you want precision definitely go for a bigger lathe. It really matters what you're going to use it for. Sometimes its better to spend a little more money and get what you need.
Also be careful using carbide, its great but it can chip too. The smoother motions you can do the less chance you risk of damaging your cutter. Its the same way for mills, unless you use CNC machines its actually recommended you don't use carbide. |
Avoid the Atlas/Crafstman 9" lathes, they are somewhat fragile. They are inexpensive for a reason. A 10" atlas will serve you well, but they tend to be rare and expensive. Even a 6" atlas is fine for precision work, if you know how to use it, but might be a little small for FRC.
Craftsman (Sears) lathes were made by Atlas, parts are identical. |
#7
If you're looking to buy a used lathe, I recommend watching this video: https://youtu.be/bP-rh6LfteU
It's a little long, but it goes really in depth in what you should be looking for when evaluating a lathe. Also, there are a couple of tips on actually moving it. |
