Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
  #46   Spotlight this post!
Unread 21-05-2016, 18:07
Aboudy Dairi's Avatar
Aboudy Dairi Aboudy Dairi is offline
Wait, people DO read these?
AKA: Co-host of the Jake & Aboudy Show
FRC #1768 (RoboChiefs)
Rookie Year: 2015
Aboudy Dairi is on a distinguished road
Re: Need a good table top scrolling CNC!
Originally Posted by asid61 View Post
Question: is it common practice to conventional mill instead of climb mill on routers, and why if so? It looks like you are conventional milling that video.
The side of the gussets is being climb milled, while the side of the scrap piece that's being tabbed is conventional milled. At least I think the pieces being tabbed are scrap because there are no holes in them and none of the corners are rounded.
  #47   Spotlight this post!
Unread 22-05-2016, 15:00
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Youtube's video stabilization makes it looks like you have a 5th axis.
I've found that I get a bit better surface finish with conventional milling over climb on a router. Deflection during conventional milling tends to be parallel to the cut rather than perpendicular when climb milling so it doesn't affect the accuracy as much and lessens the chatter marks.
2016: FRC 865 Mentor
  #48   Spotlight this post!
Unread 23-05-2016, 13:04
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by JohnFogarty View Post
Now this post is interesting. Where can you buy the cheaper Chinese spindle?
I'm pretty sure I might go the Velox route.
eBay, just search CNC router spindle
Originally Posted by Aboudy Dairi View Post
I noticed this on their website too, but is it mandatory to send a computer to their shop in order to install software?
No, but it does mean what you receive will have been tested as working at their shop before it leaves. They ran into issues installing on our an we had to set it up ourselves at our shop, would not recommend do it unless you have someone really familiar with networking and CNC setup.
Originally Posted by Frank Neuperger View Post
Robochair,
What tolernaces (in aluminum) are you achieving with your velox setup?
Have you benchmarked your machine for accuracy or repeatability?
i.e. using an indicator , have it return to a reference surface in each of the 3 axis.
Does your CAM or controller allow you to map your lead screw to enhance accuracy? If so, how many points will it allow?
Did you have to adjust scale in any of the 3 axis after you set up the machine?
One or 2 lead screws to move the gantry (low axis) ?
Do the anti backlash nut assemblies require maintenance or periodic adjustment?
Also, which model and size Velox did you buy for $6k?
It makes gearboxes every time so I never felt the need to measure it out, but for sure under 2 thou when done with a finishing pass.
+- 1 or 2 thou, we operate the machine off of a work coordinate system saved in the machine. So that repeatability is based off the zeroing to the sensor switches, the machine is tighter than that.
Yes it does, but the leadscrew nuts are all backlash compensating anyway there is no need to tune the settings to avoid backlash.
No we did not.
Yes the Y-axis has 2 screws and can be zeroed to the switches separately while unpowered to square up the gantry.
The lead screws need to be oiled often so they don't sound like Chewbacca sounding a battle cry, other than that nothing else.
The 4x4(50"x50") model.
We only climb mill.
Correct sir.
EDIT: In regards to a prior post I rechecked our invoice and the default Educational Discount is 10%, not the 5% I listed.
11 Years and counting! Over a third of my life has been spent with FRC.
