Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
  #61   Spotlight this post!
Unread 06-03-2016, 10:30
Re: #25 Chain
Originally Posted by Billfred View Post
...the cotter pins are more likely to hit something and fail...
I'm understanding you to say the failure mode is external impact damage to the cotter pin. It's not wear or normal shock loads or fatigue failure. Is that correct?
  #62   Spotlight this post!
Unread 06-03-2016, 10:43
Billfred's Avatar
Billfred Billfred is offline
Re: #25 Chain
Since we run chain-in-tube, it's tricky to get a definitive answer here. But from what we can hear and make educated guesses on, external impact damage is a very real possibility. Runner-up would be shock loads; generally speaking, we didn't get enough runtime on the failed ones to make me believe it's fatigue.
  #63   Spotlight this post!
Unread 06-03-2016, 10:59
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We're running a versachassis with 6 8" wheels on 25 chain with standard sprockets (18t?) and haven't had any issues after a full competition with plenty of defence crossing and hard defence. We did have one failure during practice due to a tensioner backing out but it was an easy swap.
2016: FRC 865 Mentor
  #64   Spotlight this post!
Unread 06-03-2016, 11:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: #25 Chain
The cotter pin is part of it, but the link is just not as strong.
The zig-zag plates in an "offset link" are set up to have complex loads on them (unlike standard links that have plates that are in very simple tension loads by design - assuming your chain sprockets are aligned properly). Anything you can do to help support that load is going to make the chain stronger.
With the cotter pin type offset link, the pin is a slip fit (the pin that carries the load, not the cotter pin). This type of joint gives less support to the zig-zap plate than in the other type of offset link, where the pin is smashed/mushroomed so that the pin and the plates are more effectively joined. Again, that better joint between the pin and the zig-zag plate translates to a stronger offset link.
And this is completely separate than from the whole cotter pins are subject to mis-application when they are so small and jewelry like.
Dr. Joe J.
Team #88, TJ2
  #65   Spotlight this post!
Unread 06-03-2016, 11:41
Re: #25 Chain
@ Billfred, Dr Joe: thanks for the added detail.
  #66   Spotlight this post!
Unread 07-03-2016, 10:02
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Re: #25 Chain
Originally Posted by Joe Johnson View Post
THIS TYPE of Half Link:
ARE MUCH BETTER THAN THIS TYPE:
Just don't even think about using the cotter pin type. Please.
Dr. Joe J.
Very confusing. Both pictures you show are under the same part number? #6261K105
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
  #67   Spotlight this post!
Unread 07-03-2016, 11:27
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: #25 Chain
Yes, sometimes McMaster links to a family of parts page rather than a particular part page. No have why.
But, when you get to the point where you actually put the part in your cart, you can usually look at the CAD link and see what the part really looks like.
The photos are there so folks can know what I was talking about without following links. I did not intend to put this or that part number into play.
Dr. Joe J.
Team #88, TJ2
  #68   Spotlight this post!
Unread 07-03-2016, 11:29
Billfred's Avatar
Re: #25 Chain
I don't know where Dr. Joe got the pictures, but 6261K105 is the one you want. It has the former's arrangement, even if the picture is of the latter. (I should know, I ordered 15 of them. Whether they arrived in time for Palmetto, welllllllll......)
  #69   Spotlight this post!
Unread 24-05-2016, 16:22
RoboChair's Avatar
AKA: Devin Castellucci
Re: #25 Chain
... and Moly B. Denum
Moly is a magical woman
11 Years and counting! Over a third of my life has been spent with FRC.
  #70   Spotlight this post!
Unread 24-05-2016, 16:25
RoboChair's Avatar
Re: #25 Chain
Shall we do a post-mortem on our drivetrains this season?
We ran into issues with our #25 drive chain and switched to #25H, no problems since.
  #71   Spotlight this post!
Unread 24-05-2016, 16:44
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: #25 Chain
We (4901) had issues with our #25 chain early in the season (at Palmetto) thanks to poor quality half links. We switched to continuous chain runs made with the dark soul tool with no half links and manually tensioned it with bolts and tensioner slots. Didn't break a chain since then. I should also mention our controls mentor Ryan implemented a SLEW control onto our drivetrain to make it so that the drivers couldn't slam full forward to full reverse instantly. That was a suspected issue causing chains to snap.
The second team I worked (5632) with continued to use half and master links. They used the "good kind" with the non-cotter pin links. They broke chain very often. They tried upgrading chain type within the spectrum of #25 chain and it only made the problem happen less often instead of solving it completely. We started with Vex Pro chain. It didn't even last 5 minutes from what I was told during testing. We upgraded to a Browning (I think) HD chain and that lasted 10+ matches normally.
John Fogarty
  #72   Spotlight this post!
Unread 24-05-2016, 17:35
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: #25 Chain
Repeatedly people keep mentioning keeping chain tight, which is especially important for #25 chain.
I've looked for a COTs chain tensioner that works like the tensioning device for a chain-saw bar and never seen such an item sold. I want to be able to loosen a locking nut, tighten the chain with a screw, then re-tighten the locking nut.
Does someone make a COTS robot device that can move the axle forward or back by turning a screw? Motorcycles have a similar set-up.
If you google 'roller chain tensioner' you get mostly all idler-wheel add-ons.
This would be an easy item to design and offer for a vendor and for 'dead' axles, you'll have to buy two for each axle bolt that needs adjusted, so potentially, eight on a six-wheel robot. That adds up profit fast.
  #73   Spotlight this post!
Unread 24-05-2016, 18:45
RoboChair's Avatar
Re: #25 Chain
The vex tensioner blocks do this with a cam. I would recommend this method as it's very easy to use.
http://www.vexrobotics.com/vexpro/al...gblocks-g.html
Or you can just wrap a zip tie around your chain run in the middle to tension it. No, I am not joking about this. It usually lasts for entire competitions as long as you are using quality zip ties.
  #74   Spotlight this post!
Unread 24-05-2016, 23:32
Knufire Knufire is offline
Re: #25 Chain
5188 ran a #25H chain drive, with 8" pneumatic wheels and no tensioners, and it was bulletproof. We ran on a four CIM drive with a 11:72 reduction, then a 18:42 chain run to the wheel. We also added 0.018" to all the chain center-to-center distances. Chains were continuous runs made with the Dark Soul Chain Tool.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #75   Spotlight this post!
Unread 24-05-2016, 23:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: #25 Chain
We ran straight #25 in a pretty bad way; direct center-to-center with sprockets outside the tube. That being said, we only threw a single chain the entire year, at SVR, due to the looseness getting extreme because of some screw holes widening (haven't checked it out for sure yet though). We did not break any chains. We used the Dark Soul chain tool to rejoin it, which I think helped a lot; we've killed masterlinks in the past.
That being said, if I had to do it again I would use sliding bearing blocks for tensioning and run 25H or 35 chain, just from fear. I was in a constant state of fear.
