Go to Post Sloppy thinking leads to sloppy designs... - Joe Johnson [more]
Unread 25-05-2016, 17:43
Spark Spark is offline
FRC #5931
Spark is an unknown quantity at this point
Re: Is Welding Worth It?
Originally Posted by techhelpbb View Post
As mentioned aluminum welds are typically not as strong as the aluminum itself. Welds can add material so they can add weight. Welds can embrittle material. Welds can cause oxidation. Welds can be deceptive.
Just adding that although welds do weaken metal you have to keep in mind that drilling lots of holes in a piece of metal for rivets or bolts can weaken it as well. Welds, if done RIGHT are the strongest option, but rivets and bolts are faster.
Unread 25-05-2016, 18:21
AdamHeard's Avatar
Lead Mentor
This is an impossible statement to make accurately with so little information.
There are applications where each is the best.
