Go to Post Has anyone else figured out a way to slip robotics into any conversation possible? Salespeople, nurse, dentist, pizza delivery guy... they all hear about it... It's gotten to the point where telemarketers will no longer call me, I have to call them... poor telemarketers... - MissInformation [more]
Unread 24-05-2016, 15:42
DevinTJRobotics DevinTJRobotics is offline
FRC #3648 (Sparta Robotica)
Team Role: Electrical
DevinTJRobotics is an unknown quantity at this point
roboRIO Connection Target issues (Failed to Ping)
Hello,
I am having a problem where I am unable to deploy code to the robot given LabView is unable to connect to the roboRIO Target. I am able to connect to the radio from my laptop (wirelessly), I am able to access the roboRIO settings through Internet Explorer using roborio-3648-frc.local (but I can't modify anything), I can't deploy code, and I can't ping the robot as it returns that the Destination Host is Unreachable. Continually I have checked all the network connection boxes so that the computer automatically obtains the IP and DNS Server addresses. Any help you can provide is appreciated.
Thanks
Unread 25-05-2016, 11:31
Re: roboRIO Connection Target issues (Failed to Ping)
It looks like you can connect to the roboRIO's web dashboard by using its mDNS name, http://roborio-3648-frc.local . Is that right?
What do you mean by "but I can't modify anything"?
How are you trying to ping the robot? What are you clicking/typing, what do you expect to happen, and what happens instead?
Unread 25-05-2016, 20:29
Please run the driver station and report whether it shows communications. If it doesn't, what does the diagnostic tab report.
Also, what is the target name in the project? You can set it via the Properties dialog for the target.
Greg McKaskle
Unread 25-05-2016, 21:08
ATannahill ATannahill is offline
AKA: Alex Tannahill
Greg McKaskle
Tacking onto this, pictures are worth a thousand words.
- Arizona North
