Go to Post You can expect to see the the same old same old again this weekend! Another set of fantastic experiences for thousands of kids across the country. And once again, Mission Accomplished. - Aidan F. Browne [more]
  #61   Spotlight this post!
Unread 05-25-2016, 06:21 PM
AdamHeard's Avatar
Lead Mentor
Re: Is Welding Worth It?
Originally Posted by Spark View Post
Just adding that although welds do weaken metal you have to keep in mind that drilling lots of holes in a piece of metal for rivets or bolts can weaken it as well. Welds, if done RIGHT are the strongest option, but rivets and bolts are faster.
This is an impossible statement to make accurately with so little information.
There are applications where each is the best.
  #62   Spotlight this post!
Unread 05-25-2016, 09:14 PM
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs will become famous soon enoughSamcFuchs will become famous soon enough
We have a student who is extremely good at welding. So, we've been welding our chassis for a very long time. Personally, I'd recommend it if you have the resources and the skills. We had 0 issues with damage to our chassis going over any of the defenses thanks to robust welds. I don't know much about it, but it seems there's a lot of depth to the skill. I'd go for it if you can.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
  #63   Spotlight this post!
Unread 05-25-2016, 10:14 PM
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Originally Posted by MrBasse View Post
Why do you grind your welds down? Are you looking for a smooth appearance or for a strong joint? In my opinion, nothing looks better than a smooth stack of weld material laid down just right especially on aluminum.
+1 Nothing looks nicer than a stack of dimes laid down.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
  #64   Spotlight this post!
Unread 05-25-2016, 10:59 PM
The Swaggy P's Avatar
The Swaggy P The Swaggy P is offline
Advocator for True Equality
AKA: John Cena
FRC #1337 (The Astliers)
Team Role: Webmaster
Rookie Year: 1776
The Swaggy P is infamous around these partsThe Swaggy P is infamous around these parts
Welding definitely helped with keeping stress points from bending and/or partially breaking.
Yes, it is expensive when compared to riveting. But the amount of metal shavings created by drilling your own rivet holes makes for a lot more cleanup, and risk of electronics shorting.
  #65   Spotlight this post!
Unread 05-28-2016, 05:18 PM
Rivet Man Rivet Man is offline
AKA: 97525A425
no team (Better than Bolts)
Rivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond repute
Hi The Swaggy P,
I'd like to address your point about rivet holes creating more cleanup and risk of electronics shorting.
Ideally you should be drilling these holes before installing any electronics! But in the off chance that you have to I'd suggest having a two man crew (never run equipment alone! HSA wouldn't like that!) Where one holds a rag and a vaccum while the other drills. Additionally I would suggest placing a cloth over top of any vital electrical equipment underneath. This should both protect your equipment and reduce the cleanup!
Hopefully this makes your life a little easier and your fastening experiences a bit brighter. Happy popping!
Also happy Memorial day weekend. God bless our troops.
Best Regards,
Rivet Man
  #66   Spotlight this post!
Unread 05-29-2016, 11:03 PM
SystemS SystemS is offline
SystemS is an unknown quantity at this point
welding is worth it if your design requires more customization than can be done to a kit bot frame. When a student is capable of welding a chassis correctly, the first time, it is quick and not a bad idea. One year a sponsor did it for us it was done wrong, after 2 weeks. That year it would have been better for a kit bot frame.
  #67   Spotlight this post!
Unread 05-30-2016, 03:59 AM
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
Why do you have to weld to have a not kitbot frame?? This year we had an 090 bent sheet metal chassis that had about 600 rivits in it with no welding.
  #68   Spotlight this post!
Unread 05-30-2016, 10:38 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
+1. Our 2014 Aerial Assist chassis was c-channel and tubes bolted together using flat angles and Ts as gussets. Even as violent as AA was, frame strength was not one of our problems.
  #69   Spotlight this post!
Unread 05-30-2016, 11:36 AM
Gdeaver Gdeaver is offline
FRC #1640
We weld, rivet, bolt, bond our robot assembles. Isn't engineering about evaluating and choosing the best method to solve problems?
  #70   Spotlight this post!
Unread 06-02-2016, 01:45 PM
Spark Spark is offline
FRC #5931
Spark is an unknown quantity at this point
If you use thin sheet alum it can sometimes be better to weld. Though usable, rivets and bolts could rip out or bend the metal. A long weld, not just a spot weld, has more surface area connecting the two pieces. However, if you need precise pieces it's easier to rivet or bolt. I'm not saying keeping welded pieces flat is impossible, just harder.
  #71   Spotlight this post!
Unread 06-02-2016, 06:09 PM
AKA: 97525A425
Hi Spark,
Going to pretend I'm Weld Man here for a second...but if you're talking about bending the metal, a continuous weld is always going to produce more warping in a part than riveting if all else is equal.
Mainly what happens is you heat up the metal and it gets softer (more malleable, and a bunch of other science jargon). So what happens is it'll distort and actually pull to a side. Afterwards there will be additional stresses inside the material (as with all fastening systems, that's how they work) that keep the material bent out of place.
Even if you preset your material and had it exactly in place, a long continuous weld is 100% going to distort a thin sheet of aluminum. Fortunately, rivets have your back and could be used to hold the sheet in place to help reduce warping.
Here's a link that has some good tips on how to mitigate these warps.
http://weldingdesign.com/archive/avo...ion-thin-sheet
Main points from this link are things like, backward walking, non-continuous/stitch welding, and presetting.
It's true that rivets can bend a thin piece of aluminum, but that would mean you have other issues in your setup. If your pieces aren't mated correctly (air gaps, bends aren't proper) when you're about to rivet then yes, rivets will bend your rig...they're trying to pull the pieces together after all! And if we're talking about the retaining mandrel or the head impinging on the surface of the metal...chances are you're using too much force on too soft a material, that ones on you and not the rivet!
Rivets are only as good as the person/design that's using them, and they're definitely not the bad guy!
Best Regards,
RM
  #72   Spotlight this post!
Unread 06-03-2016, 11:12 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
There is a school of though that suggest stitch welding may be superior to seam welding for certain applications. If a crack starts in a stitch weld it will break through one stitch and then stop, providing a good visual cue to the operator/maintainer, and easy access for repair. If a seam weld cracks or un-zips it can propagate a large distance before it is detected and may be more difficult to properly repair.
What makes seam weld cracks harder to repair is guessing where to drill the stop-hole for the crack, because a crack will propagate further than is visually detectable. Of course X-ray or magnaflux (and other technologies) can help, but that's a whole other level from FRC. With a broken stitch weld the whole stitch can be cut and re-welded (if not already broken) with no need for a stop hole.
I'm going to stop myself here on the 'seam vs stitch' discussion unless there is a debate or questions that arise.
Originally Posted by Rivet Man View Post
Hi Spark,
Best Regards,
RM
To put some 'science jargon' there...
The metal will change shape due to extreme localized heating of the weld pool driving thermal growth of the material. Any softening is secondary this CTE (coefficient of thermal expansion) driven growth.
Warping can be managed by proper design, small or non-existent root gaps, fixtures, and sufficient tack-welding prior to seam welding. If a part comes out warped there are many ways to correct it that include bending, re-heating welds (sometimes with fixtures), cutting, stress-relieving (sometimes with fixtures), or any combination of the above.
  #73   Spotlight this post!
Unread 06-03-2016, 11:18 AM
ChristianSpring's Avatar
ChristianSpring ChristianSpring is offline
ChristianSpring is an unknown quantity at this point
Welding is the most appropriate thing to do in this situation.
  #74   Spotlight this post!
Unread 06-03-2016, 11:39 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If you want to see lots of examples on how to weld thin sheets, google automotive sheet metal repair. It is mostly done with steel, but lots of YouTube video. Welding in such a way to minimize distortion is an art and science. For heavier weldments you have to calculate and allow for shrinkage. There is only so much that stress relieving will do.
One large scale example of thin sheet frames are airplanes. They are mostly riveted or glued and riveted.
  #75   Spotlight this post!
Unread 06-03-2016, 12:06 PM
mwmac's Avatar
mwmac mwmac is online now
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Some eye candy of the art of welding sheet aluminum...(click on build photos)
http://www.p4bynorwood.com/
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
