Go to Post Thermodynamics says that offense is harder than defense. - dtengineering [more]
Unread 25-05-2016, 10:36
Harry1 Harry1 is offline
FRC #4463 (The Blaze)
Harry1 is an unknown quantity at this point
Want to buy Andymark AM-14U3 Chassis
Does any team still have a complete am-14u3 chassis kit that they would like to sell? We are looking for another one for an off-season project.
Unread 25-05-2016, 10:52
Knufire Knufire is online now
Re: Want to buy Andymark AM-14U3 Chassis
If you can't find one from a team, you can get one from AM.
http://www.andymark.com/AM14U3-p/am-14u3.htm
If you're doing tank drive, the frame portion of the AM14U2 should be functionally identical for you too.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 25-05-2016, 13:56
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We never took ours out of the box, we will sell it to you. Send me a PM
Remember why you're doing this.
Unread 25-05-2016, 20:26
Billfred's Avatar
Billfred Billfred is offline
The AM14U2 is still available here. And it's on clearance, too!
Unread 25-05-2016, 23:05
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
How different is the U2 vs U3?
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 25-05-2016, 23:08
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
The main difference is wheel size (4 vs 6) and gear ratios.
461 Westside Boiler Invasion
45 Technokats
Unread 25-05-2016, 23:13
Billfred's Avatar
I don't have the full list of changes (I've only been here two days!), but...
The AM14U2 will run a 6" or 8" wheel with different axle placement and belts. And since the item on the website is just the frame, you can pick the ones that work for you.
Unread 25-05-2016, 23:28
I believe they're (nearly) identical for tank drive configurations; a churro standoff hole might have moved.
Biggest differences in the frame itself was the removal of the BaneBots P220 mounting holes and the addition of mounting holes for the TB Micro. There's also a sneaky trick on the U3 that allows you to run 4" Mecanum wheels with the TB Micros; I believe the U2 only supported 6" and 8" mecanum setups.
Unread 26-05-2016, 00:34
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
The AM14u2 will run a 6" or 8" wheel with different axle placement and belts
The AM14u2 can use 6 inch wheels with the exact same axle placement and belts , if you simply cut slots into the front and rear pieces of the chassis(not very difficult, with a hacksaw or a reciprocating saw)
Unread 26-05-2016, 08:14
Billfred's Avatar
You certainly can, and I know teams that did that in 2015. But without knowing the nature of the off-season project, especially given the abuse robots can take at a tournament this year, I'm a little loath to recommend that technique. (And besides, the AM14U2 is only sold as a frame--so you have to select belts.)
Unread 26-05-2016, 11:03
InFlight's Avatar
InFlight InFlight is online now
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
As an offseason project, you could also try to learn how to build a non-premade kit drive train. Something like the Versa Chassis would let you layout your own drivetrain and frame design. You don't need anything beyond hand tools to assemble one. The ability to adjust your frame perimeter to a particular games challenges can be a very valuable capability.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 31-05-2016, 15:22
AdamHeard's Avatar
Lead Mentor
The 2015 Chassis is $74 today only....
http://www.andymark.com/AM14U2-p/am-2990.htm
Might be worth the hassle of the slight difference to save a few bucks.
