Go to Post You can expect to see the the same old same old again this weekend! Another set of fantastic experiences for thousands of kids across the country. And once again, Mission Accomplished. - Aidan F. Browne [more]
Unread 23-05-2016, 12:39
hank2247's Avatar
hank2247 hank2247 is offline
FRC #4388 (Ridgebotics)
hank2247 will become famous soon enough
Re: Lathe Suggestions
I would definitely recommend buying the largest lathe you can afford. An old used lathe (hardinge, monarch, hendey) will be better than a modern machine but can be harder to find.
http://www.grizzly.com/products/12-x...campaign=zPage
these seem to be pretty good for the price and size.
Unread 23-05-2016, 13:10
RoboChair's Avatar
AKA: Devin Castellucci
Seconded. Grizzly is better than most cheap end machines.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 23-05-2016, 13:19
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Quite a few other good American Lathes to consider used including South Bend (9 Inch, 10 Heavy), Atlas or Craftsman 9 inch, Clausing, Leblonde, Lodge & Shipley, and Sheldon. Need some experience when buying a used lathe to evaluate it's condition, and understand what parts are present, or if replacements are available. (total cost).
Other than HASS, there are no domestic lathes in production. The current South Bend ones are all imports.
If you have limited shop space; a Bench Top to unit would be the way to go. Otherwise their are a lot of "tool room" sized lathes in the used market.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 23-05-2016, 14:49
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Hardinge and Monarch both still make HLV-H and 10EE lathes...but they are custom order and the last I heard a 10EE was over $100,000...so not exactly FRC friendly from a budget standpoint.
Standard Modern makes lathes in Canada, which afaik is the only North American lathe still in regular production. They are not cheap though. I got a quote last fall just to see and a 1340 was $16,000 and a 1640 was $27,000.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-05-2016, 16:19
Spark Spark is offline
FRC #5931
Spark is an unknown quantity at this point
Smaller lathes are cheaper, however smaller sizes can be killers on precision. If your doing non-critical shapes then small lathes are good but if you want precision definitely go for a bigger lathe. It really matters what you're going to use it for. Sometimes its better to spend a little more money and get what you need.
Also be careful using carbide, its great but it can chip too. The smoother motions you can do the less chance you risk of damaging your cutter. Its the same way for mills, unless you use CNC machines its actually recommended you don't use carbide.
Unread 25-05-2016, 16:29
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Look for a Hardinge HLV-H tool room lathe. They are wonderful machines and can be found in your price range
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 25-05-2016, 18:06
DonRotolo's Avatar
Back to humble
FRC #0832
Avoid the Atlas/Crafstman 9" lathes, they are somewhat fragile. They are inexpensive for a reason. A 10" atlas will serve you well, but they tend to be rare and expensive. Even a 6" atlas is fine for precision work, if you know how to use it, but might be a little small for FRC.
Craftsman (Sears) lathes were made by Atlas, parts are identical.
Unread 25-05-2016, 21:12
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Please find me an HLV-H for $3k, I want one. Maybe it's just CA, but I've never seen a good one for less than several thousand $.
I also wouldn't trust a high school kid with one (and I am a high school kid) just because they are so nice. It would be a shame for one to get killed.
Unread 25-05-2016, 21:33
scottandme's Avatar
scottandme scottandme is online now
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Look for the "TFB-H" - same as the HLV-H but without the threading gearbox. Might catch one cheaper, but be careful that it isn't run into the ground, since a lot were used for production parts. 10ee's are beautiful as well, but make sure you do some research on the specific model/model year. The controls can be tricky to sort out.
Otherwise - the Taiwanese machines are generally nicer than the mainland China manufactured machines. Lots of brands sourcing from the same factories and putting their label on it (Precision Matthews, Eisen, Victor, Sharp, etc).
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 25-05-2016, 23:39
My mistake. A quick search led me to Hardinge DV-59 lathes, not the HLV-H I expected. After looking more, I also would gladly accept a $3k HLV-H
Unread 26-05-2016, 01:18
Cory's Avatar
AKA: Cory McBride
You cannot find a good HLV-H for less than $10-14k, at least around here.
A TFB-H that isn't beat to hell and back won't be in OP's budget either. We spent $8k on ours. Without DRO and accessories it was $5000something.
2001-2004: Team 100
Unread 26-05-2016, 01:50
RoboChair's Avatar
There was one on Craigslist for $2k for about 6 hours a couple of weeks ago >_>
Unread 26-05-2016, 05:59
Michael Hill's Avatar
If you're looking to buy a used lathe, I recommend watching this video: https://youtu.be/bP-rh6LfteU
It's a little long, but it goes really in depth in what you should be looking for when evaluating a lathe. Also, there are a couple of tips on actually moving it.
Unread 26-05-2016, 07:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For someone like me who is not an expert on these Hardinge lathes, what is the difference between these two models?
Unread 26-05-2016, 08:25
scottandme's Avatar
AKA: Scott Meredith
No threading gearbox on the TFB-H. "Turn, Face, Bore" only.
