Go to Post What's a pirate's favorite robotics tournament? Aye-arrrrrrrrrr-aye, matey! - John Wanninger [more]
Unread 27-05-2016, 10:53
caume's Avatar
caume caume is offline
AKA: Cameron Aume
FRC #3324 (Metrobots)
caume is infamous around these partscaume is infamous around these partscaume is infamous around these partscaume is infamous around these partscaume is infamous around these partscaume is infamous around these parts
Hex Kiwi Drive
Over the past few weeks, I have been working on a hex kiwi drive train. It is a six-sided drive, with an omni wheel on each side. This allows for nearly identical speed and pushing power in every direction. A rough weight estimate of this is ~35lb, without bumpers, battery, or electronics.
Specs:
  • 12:64 Drive Ratio
  • 4 inch Omni Wheels
  • Theoretical Speed: 17 ft/s
  • Stall Force: 196-227 lb, depending on direction
If you see any mistakes after looking at this, please let me know! Thanks!
ID:	20805  Click image for larger version
ID:	20806  Click image for larger version
ID:	20807  Click image for larger version
Unread 27-05-2016, 10:56
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Hex Kiwi Drive
i would definitely work on adding some gussets or other type of support between the drive rails and the upper frame. Looks like it only held on by 6 standoffs right now. Keep in mind all of the force of a defense hit goes into the bumpers, so you want that connection to be really strong.
Also, keep in mind pushing with omnis isn't very efficient. The major point of an omni directional drivetrain is to avoid collisions.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 27-05-2016, 11:07
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Hex Kiwi Drive
That might be a tad fast even for 6 CIMs, because of brownouts. Apart from that, I really love this implementation.
Your CIMs appear to be bleeding into the bellypan.
Have you thought about using the Vex clamping gearboxes instead of custom? I like your implementation as it keeps this low to the ground, but it's something to think about.
EDIT: Missed the upper fame. As Jay said, adding some 2x1s or something with cuts to that they fit into the main rail and upper rail would be much more secure.
Unread 27-05-2016, 11:10
caume's Avatar
AKA: Cameron Aume
Re: Hex Kiwi Drive
I was thinking the same thing about the bumpers.
For the omnis, shouldn't coefficient of friction be high in the direction of the wheel? The added pressure from the sides of the rollers should help, no? The reason omnis are used to get away is because they are more maneuverable, but if the rollers aren't consistent in every direction, they should be good for pushing, I thought.
Unread 27-05-2016, 11:15
Division by Pirates
Re: Hex Kiwi Drive
Not sure what you mean by added pressure from the sides of the rollers, so forgive me if my thoughts don't make sense with yours.
The main issue is that most collisions are directly applied to a bumper side. This means that only two of your wheels will be driving directly against the pushing robot, and you're not using all of the power that you have efficiently since the driving vectors are at an angle.
Edit: other problem with omni directional drivetrains like this is that it is easier to get pushed from the side and be moved. A good driver can get out of it, but usually it ends up not being worth it.
Unread 27-05-2016, 11:20
caume's Avatar
AKA: Cameron Aume
Re: Hex Kiwi Drive
My original version of the cad actually used the vex clamping gearboxes. My team has had problems with motors sagging down, so I went on to make the motors lower, with cutouts in the bottom plate. The idea was the bottom plate would support the motors a bit. I attached the other images.
Unread 27-05-2016, 15:20
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Re: Hex Kiwi Drive
So I have difficulty seeing what previous game a hex chassis would be effective for. Would someone care to enlighten me on what benefits there are for having a hex chassis? I feel that an H drive or mecanum is a more efficient way of driving for you still have the omnidirectional movement. Also, with the electronics that would need to be added, I do not see how attachments could go onto the robot without having a tangled mess of wire and electronics on the belly pan. Perhaps even an additional pan would be good for adding attachments... I know Simbotics used a kiwi drive in 2015 in a non defensive game, but their chassis was not a hex like the one shown above. So why Hex and why kiwi?
EDIT: can you send me the CAD so I can review it some more?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 27-05-2016, 15:22
caume's Avatar
AKA: Cameron Aume
Re: Hex Kiwi Drive
Hex kiwi could be really good 2014, or any flat field really, because it can be so fast and maneuverable
Unread 27-05-2016, 15:24
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Re: Hex Kiwi Drive
So how would you be able to get a shooter or kicker on the robot?
Unread 27-05-2016, 15:46
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Hex Kiwi Drive
To be fair, 148 won a Championship with a nonagon chassis.
Academic Student (Forever)
Unread 27-05-2016, 16:08
Re: Hex Kiwi Drive
The frame had nine sides, true. Count the wheels, though.
Unread 27-05-2016, 16:44
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Re: Hex Kiwi Drive
Most likely not 6...
Unread 27-05-2016, 16:48
caume's Avatar
AKA: Cameron Aume
Re: Hex Kiwi Drive
To counter that argument, look at like 90% of the robotics this year, 6WD. This is just a fancy 6WD if you think about it
Unread 27-05-2016, 16:58
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Re: Hex Kiwi Drive
True true didn't think about our own robot
Unread 27-05-2016, 18:06
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
Re: Hex Kiwi Drive
148 had a three wheel swerve drive that year.
