Go to Post The more women we have as 'rock stars' in FIRST, the more girls we'll see celebrating math and science and the doors they can open. - JaneYoung [more]
Unread 27-05-2016, 00:09
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Is it legal to make a custom slip ring?
I was wondering if it is against First's rules to make a custom slip ring commonly used for swerve modules if you all have any insight to this, it would be welcomed
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 27-05-2016, 00:11
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Is it legal to make a custom slip ring?
Not legal for power lines according to last year's game manual; you are not allowed to use CUSTOM CIRCUITS there. This has been a rule for several years.
I'm not entirely clear what the rules are for signal wires, however, it's definitely in the manual where it talks about custom circuits.
Unread 27-05-2016, 02:00
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
R55 wouldn't permit a custom circuit in the motor power wire path.
COTS slip rings are permitted, non Mercury. There are some inexpensive wind turbine ones in the 30 Amp range. I never found any 40 Amp ones that would be legal for a CIM that were reasonably priced.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 27-05-2016, 07:56
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Got links to the ones you did find?
Unread 27-05-2016, 08:25
InFlight's Avatar
AKA: Jim
Most the ones sold on Amazon and elsewhere are Moflon MW series. (www.moflon.com)
The 30 Amp ones are realively cheap and a nice size.
They then step to 60 Amp which are quite large to package and too expensive for a Swerve drive.
Unread 27-05-2016, 09:21
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
It looks like you can get the MW1430 for around $55. It has 4 contacts, each rated for 30A... what about running the contacts in parallel? This is something I would want to ask the GDC before implementing, but running 12 gauge wire up to the slip ring, splitting each wire across two connectors in the slip ring, then combining them again when you go into the CIM motor. It would be an interesting way to get around the 30A limitation! Not really convinced the GDC would think it legal, though.
2016: Lake Superior WFFA
Unread 27-05-2016, 10:56
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Probably not the GDC's cup of tea, I would imagine, but for something like a turreted shooter that would be really handy.
EDIT: As a side note, to date I have not found a non-coaxial or coaxial design lighter or more compact than 1323's coaxial design this year last year. It integrates many parts together that cannot be integrated on a non-coaxial, so it saves a lot of weight and space. The only issue with it is how to add encoders, and that can easily be solved by using an AMT-103 on the CIM shaft or a gear tooth sensor on the CIM pinion.
Unread 27-05-2016, 11:12
InFlight's Avatar
AKA: Jim
R50 Branch circuits may include intermediate elements such as COTS connectors, splices, COTS flexible/rolling/sliding contacts, and COTS slip rings, as long as the entire electrical pathway is via appropriately gauged/rated elements.
Seems like it would be legal with 12 AWG elsewhere. The downside is there would be no contacts available for any kind of speed measurement for a motor on pivot swerve.
I spent sometime looking at these, and decided a coaxial swerve was a simpler approach from my viewpoint.
Unread 27-05-2016, 11:19
The question is... Are two connectors each rated for 30A, placed in parallel, gauged correctly for a 40A branch circuit? I could make an argument in either direction. It really would need a GDC ruling on it through the Q&A.
Unread 27-05-2016, 11:24
foote stepped in
AKA: E. Foote
FRC #0868
And next year's rules around the electrical side could very well be different.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 27-05-2016, 14:52
InFlight's Avatar
AKA: Jim
It would be good to see an official Q&A ruling.
I would suggest a reference to NEC sections 310.10H and 310.15(B)(3)(a) as guidance to amperage rating of using parallel conductors in a slip ring module.
For a Four Conductor Module you should be approved for 80% of the conductor amperage rating of each individual wire pair, provided they are same overall length.
Thus with two + two of the four conductors in parallel, the Rating should be = 2*30A*0.8=48 amps
Unread 27-05-2016, 16:47
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
There is a safety concern in using two connectors. In normal motor circuits, if a wire comes lose, current stops flowing (until the loose wire shorts to the other side of the circuit and trips the breaker). If a connection breaks loose to one of the slip ring connectors, you now have 40A going through the 30A remaining ring -- and things start to heat up -- the slip ring conductor is your breaker, and not a very good one
I'd think that overloading a circuit due to losing half the conductor might have more danger than the lower risk of suddenly shorting something and blowing a breaker immediately.
Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of...
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 27-05-2016, 17:44
InFlight's Avatar
AKA: Jim
The specified current carrying capability of wires is highly derated vs. their actual capability at room temperature conditions. (Likely 2x or more). The National Electric Code is very conservative, and it permits parallel power feeds.
The CIM motor is wound with magnet wire that is a very small fraction of the circular mills of either a 30 or 40 amp wire. The internal brush connections are not that large either. If you provided a constant 40+ amp load to a CIM motor with 30 amp wiring, the CIM motor would in all likelihood be the first source of failure. It simply can't reject the heat fast enough.
Unread 27-05-2016, 20:03
DonRotolo's Avatar
Back to humble
FRC #0832
Could you power such a CIM through a 30A breaker and thus be fully compliant?
Unread 28-05-2016, 18:42
InFlight's Avatar
AKA: Jim
R48 allows Motor Controllers with "Up to 40A" Circuit Breakers. Thus a 30Amp breaker would be compliant when paired with a 30A rated slip ring.
The problem is a 30 amp breaker has much less margin when you get into a pushing match and are monetarily drawing high current. Same could happen running into an obstacle during autonomous. The stall current of a CIM Motor is rated at 131 Amps.
Might be fine depending on the game; but I have no experience running a CIM with anything but a 40A breaker.
