Go to Post You will forever be confronted with choosing between right and wrong, or choosing what you think you can get away with. Which way you go defines what kind of person you are. Choose wisely. - Gary Dillard [more]
Unread 28-05-2016, 07:38
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: FRC Primer for Programmers
The intent is to give a high level overview. Not to make them experts. The idea is to give them context for what they will see in the production robot code. Knowing the sequence of calls from fms helps in understanding what gets called when in the robot code.
Once the high level overview is created, I could see expanding each topic to a more in depth tutorial.
Note: the purpose is not to entertain. That is for others to work on. The purpose is: in order to understand the code, here is what you need to know. Enough to understand, not enough to program.
Sitting around watching the experienced programmers is no fun if you have no idea what they are doing.
