Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 28-05-2016, 12:33
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Need help with X-TBA-App-Id Header for TBA API
What exactly am I supposed to put in the header when requesting?
For the FRC Events API V2.0 the header I use is
"Authentication: Basic *my auth key*"
What do I use for the TBA API Header? I have tried
"frc3991:scouting-system:v01"
and
"X-TBA-App-Id: frc3991:scouting-system:v01"
Neither have worked, I'm prob just missing something simple . Thanks for the help.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 28-05-2016, 12:56
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: Need help with X-TBA-App-Id Header for TBA API
What you have should work just fine. Are you sure you're making the request with that header? If you're using a Web request function in a programming language, usually you have to set headers by name (something.setHeader("X-TBA-App-Id", "my:app:id") )
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 28-05-2016, 13:09
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
this is probably very inneficient but for the FRC API i used a php method I found online
<?php
$opts = array(
  'http'=>array(
    'method'=>"GET",
    'header'=>"Authorization: Basic *My Auth Key*"
$context = stream_context_create($opts);
$apiurl = "https://frc-api.firstinspires.org/v2.0/2016/matches/TXHO?tournamentLevel=qual&matchNumber=*";
$file = file_get_contents($apiurl, false, $context);
echo $file;
That works so I tried to do the same thing with the TBA Api
<?php
$opts = array(
  'http'=>array(
    'method'=>"GET",
    'header'=>"X-TBA-App-Id: frc3991:scouting-system:v01"
$apiurl = "www.thebluealliance.com/api/v2/team/frc3991/2016/events";
echo $file;
but I get nothing back... (also tried only frc3991:scouting-system:v01 without the X-TBA-App-Id: portion in the header, didn't work)
Unread 28-05-2016, 13:19
Jaci's Avatar
Rookie Year: 2015
Do you get nothing back, or a JSON-ified error message?
Jacinta R
OpenRIO : Owner
Unread 28-05-2016, 13:20
Michael Hill's Avatar
Something changed recently (not sure what), but sometimes you may have to send a User-Agent header string as well.
Unread 28-05-2016, 13:52
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Oh hell, i forgot to http:// in fornt of the url, the code was searching for the site locally without it, thanks for the help guys
Code that works if anyone cares:
<?php
$opts = array(
  'http'=>array(
    'method'=>"GET",
$apiurl = "http://www.thebluealliance.com/api/v2/team/frc3991/2016/events";
echo $file;
Unread 28-05-2016, 14:00
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
That's a very... "PHP" way of handling a lack of protocol, lol! Glad you got it all figured out.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 28-05-2016, 14:12
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I'm pretty sure this is caused by CloudFlare somehow (it's DDON protection might automatically stop requests that come from scripts). It's difficult to trace because it only seems to happen sometimes.
Unread 28-05-2016, 18:48
Cabey4 Cabey4 is offline
Vision/Scouting/Strategy/Too much
AKA: Tom Schwarz
Rookie Year: 2015
Cabey4 is on a distinguished road
Hi, I had this same problem a while ago, where it would give me error 403, forbidden.
I found that I had to add a header called 'User-Agent' with "Mozilla/5.0 (Windows; U; Windows NT 5.1; it; rv:1.8.1.11)Gecko/20071127 Firefox/2.0.0.11" to make it think it was a web browser and wouldn't get blocked.
My code for my (python) thingy is https://github.com/Cabey4/4613-Auto-Scout
but it looks like you've already sorted it. But if anyone else gets a 403 forbidden error with the TBA/The Blue Alliance api that's probably why.
Unread 28-05-2016, 19:04
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
You can make things a hell of a lot simpler with the requests library. Just make sure you do
pip install requests
to install it and suddenly you've made everything loads easier (example).
Unread 29-05-2016, 11:53
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Really, it is the fact that PHP even lets you use "file_get_contents()" to make HTTP requests. "file_get_contents()" is better suited for local files, and CURL or something more elegant that probably wraps CURL for remote HTTP requests.
--Jacob
Illinois FTC FTA
Unread 29-05-2016, 14:12
synth3tk's Avatar
AKA: David Thomas
I didn't even catch that, thanks. I'm assuming that they have some reason for using file_get_contents. If not, OP, you should look into CURL.
Unread 29-05-2016, 14:16
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Ya, I was only using file_get_contents because I already knew how, but I will look into CURL thanks!
Unread 29-05-2016, 14:52
Oscar Lewis's Avatar
Oscar Lewis Oscar Lewis is offline
FRC #2557 (SOTABots)
Oscar Lewis is on a distinguished road
I am also currently using file_get_contents() mostly because I am only ever fetching a JSON array once (and it's only needed to set up a MySQL database once per event for scouting) but how I am forming it is
$jsonurl = "http://www.thebluealliance.com/api/v2/event/$eventcode/teams?X-TBA-App-Id=frc2557:pnwscout:v01"
or in your case
$jsonurl = "http://www.thebluealliance.com/api/v2/team/frc3991/2016/events?X-TBA-App-Id=frc3991:scouting-system:v01
Glad you got it all sorted out!
