Go to Post Problem with microprocessors: they do exactly what you tell them to do - KenWittlief [more]
Unread 28-05-2016, 22:55
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
.stl to .cube3 conversion
Team 2855 is trying to print our logo on our Ekocycle Cube printer. We have found that the current version of the Cubify software will not convert the file. We are wondering if anyone else has an older version of Cubify and would be willing to convert it for us. You can PM me and I can get the file to you.
Or, if anyone knows how to get the printer to recognize and print .stl files or any other type of standard file.
Thanks
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 29-05-2016, 00:24
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
Re: .stl to .cube3 conversion
Thanks
If the ekocycle is like most lower-end FDM printers that I am familiar with, it won't be able to print directly from an STL, it must be sliced first. If the ekocyce software won't accept STL, you'd likely have to export from your CAD software it to a different file type, like .obj. I'm pretty sure you guys are using Solidworks, which can handle the conversion no problem. If you're still having trouble, I can stop by your shop anytime the next few days.
4536 Team Captain
www.minutebots.org
Unread 29-05-2016, 00:33
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
I actually figured out the problem: it was the file. It had some errors, such as missing a bottom (it was made in sketchup, due to the ability to draw over a drawing). It works now. Thanks though!
2. Wire the robot
7. Be active on CD
Unread 29-05-2016, 00:52
Ace Machinist
Would you mind posting your solution, in case anyone else is having a similar problem?
4536 Team Captain
www.minutebots.org
Unread 29-05-2016, 00:55
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I'd be more than willing to review stl files for anyone, we have some software at Stratasys that is good at fixing any issues. Shoot me an email at evan.hochstein(at)stratasys.com
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 29-05-2016, 12:40
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
So, when I was drawing the file, I had made a rectangular plane so I could add the image to it as a texture. After I was done drawing the logo, I deleted the plane. That removed some relationships and the bottom of the model. It was able to be saved as a .obj file, but when opened in 3D Builder, it said there were errors in the file, but didn't prevent me from converting it to a .stl file. I opened it in Cubify, and it wouldn't build a print file, due to those errors.
Now, the way I fixed the problem was by redrawing the logo, but this time leaving the plane. I saved it as a .obj file, and opened it in 3D builder. It said that there were errors in the file, but this time, I believe it was because of the plane that had no volume. I was able to let 3D Builder repair the file, which removed the excess file. Then I was able to open it in Cubify and successfully convert the file to a .cube3 file.
2. Wire the robot
7. Be active on CD
