Go to Post FIRSTers in particular want very strictly delineated guidelines so that they know exactly what parameters under which they're working, except when they don't. - pfreivald [more]
Unread 30-05-2016, 23:18
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Re: Sheet Metal vs Tube Drivetrain
Originally Posted by asid61 View Post
Chain is also used in engines, though. And teams have run center-to-center chain, most notably us this year. Seriously though, 118 ran (and might still, I can't recall what they did this year) chain-in-tube C-C for years.
Chain technically doesn't stretch, but it does wear, albeit slowly. For us, chain wear was far less of a problem than bearing blocks getting closer together due to hole clearances. Last year we ran on one tension of chain for the whole season without any problems. I would say chain is the easier of the two due to the sheer amount of forgiveness it has (and it's ability to replace 20 pitch gears, but that's for another time).
There also seems to be a rare recurring problem of belt picking up field tape, although I have no idea why.
That is weird lol, though you when chain get slack it has sideways play meaning if you run chain too close to a bolt or wheel, you'll run into some problems. Belt has not play, and it can take a hit and be fine, though it really just comes down to what works best for the individual
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
