Go to Post First is more than a competition it is a family. - amos229 [more]
  #33   Spotlight this post!
Unread 05-31-2016, 05:40 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: The negative effects of FRC
OP, I'm curious.
A) It appears you were focused on building a great on-the-field robot, and on getting far down the path to Einstein? Is that true? If I'm wrong, ignore the next question.
B) How do you think you would feel (then and now) if instead your last year/season had focused on getting as many non-STEM students as possible to try STEM things that they hadn't done before, while also helping build a fun, adequate, middle-of-the-road robot? If you did do that, along with everything else you described, my advice is to stop volunteering for too much bad stress. If you didn't, I'm sure that FIRST wants participants to use the FRC program to place a greater emphasis those non-STEM students than participants place on the robot.
Creating the robots and going to competitions is an FRC tool, not the FRC goal. It's very easy to shed bad stress if you look at things that way. Shedding bad stress, is a good thing.
Blake
