Re: Vex Shift Rod through 3/8 Hex Shaft?
+1 on using a smaller custom rod.
Using a 3/8" hex shaft could be possible if you used custom Dog stuff, but ballshifting would be very tricky. On the plus side, you could use the 3/8" x 7/8" flanged bearings, which are very compact, for your dog gears. Using two different pitch gears on a shifter seems interesting but also risky. The main thing I would be worried about if you reduced the rod diameter is the little shifty bit (4-40 screw in WCP dogs). SW stress analysis could make sure it's safe. |
Use 1018 cold rolled steel. Stock bar is available in 0.125 and 0.1875 sizes.
You will need to have bearings in the pneumatic shift interface. Sticking with standard fractional sizes will make it easier to source bearings (R2 and R155). ** Edit- you could look at available Metric shaft as well. ** Last edited by InFlight : 06-01-2016 at 08:37 AM. |
Solidworks Simulation can help you calculate what effect the same torque has on the original 3/8" hex compared to the new one. Or you can plug in equations you find online for the strength of a tube versus a rod in torsion. Last edited by asid61 : 06-01-2016 at 06:18 PM. |
I guess this would counter that a dog gear doesn't make a great brake. Compared to a traditional brake, not so sure. I don't really know what traditional brakes look like (... is it a bike brake?). Quote:
#7
If this is an off-season project/design you might have enough to try some other methods of braking such as a disc brake.
#10
I've seen a lot of disc brakes in Recycle Rush for the lift mechanism. However, for my intentions I'm not sure if I would be able to fit one in the gearbox I'm making, even if it is a custom-manufactured part. You are right though. Offseason is a great time to explore new concepts and designs: something I failed to do last offseason by designing WAY too many drive gearboxes and drivetrains. |
#11
Sorry thats whats I get for responding on mobile. But yes hole smaller or shaft bigger. I would personally use a 3/16 shaft with a .201 or .196 clearance hole.
