Go to Post Welcome to CD! (just be careful..........it's addictive! :D ) - Jay H 237 [more]
Unread 31-05-2016, 20:44
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Is Magnesium ok?
As many have noted, Magnesium in typical form is no more dangerous than any other metal - even underwater. However, smaller chips or particles are able to be ignited, and then become extremely difficult to extinguish.
Yes a class D extinguisher has a chance, but hav limited effectiveness and are costly.
If you use the metal and don't need to machine it, you'll be fine. But if it needs to be machined, you are better off avoiding it. The risk is small but the consequences very large.
Unread 01-06-2016, 00:38
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by Mike Schreiber View Post
Wasn't the housing on the NI cRIO magnesium? No one started any fires - although hopefully no one was machining it.
No, it was almost certainly certainly steel. Those things were heavy!
Unread 01-06-2016, 00:50
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
One of the reasons magnesium (and it's alloys) isn't used much is because it corrodes at a very high rate in comparison to aluminum.
In terms of strength to weight ratio, both Titanium and Alluminum are ahead of Magnesium.
Magnesium prices tend to be volatile, cost is typically quite a bit more than Alluminum but less than Titanium. Magnesium tends to be used for castings and occasionally forgings;, but not normally drawn bar/sheet or extrusion stock.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 01-06-2016, 08:09
Nate Laverdure's Avatar
FRC #2363
Nope, it's aluminum.
Unread 02-06-2016, 06:02
barevalo barevalo is offline
AKA: Bryan Arevalo
FRC #3476 (Code Orange)
barevalo has a spectacular aura aboutbarevalo has a spectacular aura aboutbarevalo has a spectacular aura about
Last time I checked, Magnesium is Mg not Ok.
Unread 02-06-2016, 09:12
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Beat me to it...
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 02-06-2016, 11:33
InFlight's Avatar
AKA: Jim
"Magnesium is OK" when it's used in Aluminum Alloys. Both the very common 6061 & 7075 aluminum alloys contain Magnesium.
Magnesium is also used in almost all Steel & Stainless Steel Alloys. MG isn't used in Titanium alloys, as it's not soluble with the any of the TI phases.
Unread 02-06-2016, 12:54
RacerX's Avatar
RacerX RacerX is offline
FRC #0948 (NRG948)
RacerX is on a distinguished road
Our racecar has many magnesium parts, injector, supercharger case, valve covers and manifold. The entire body was made of magnesium sheet.
We have done quite a bit of machining, drilling and tapping of these parts, and never had any issues. But, we did make sure that all shavings were disposed of properly, and were kept from any ignition sources.
It does corrode if left untreated. Most all of our parts were Dow 7 dipped for a coating. They looked nice....
http://www.chiefdelphi.com/forums/at...d=14648864 51
Unread 02-06-2016, 17:14
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
Originally Posted by Cory View Post
I see no real safety risk associated with magnesium in the operation of the robot or in the pits at an event.
That being said, you could burn your shop down if you are milling/turning/sawing it and create fine chips that accumulate and aren't cleared out of the machines.
Cory accurately identifies the hazard of working with magnesium. It's not so much with the robot in competition.
My camera body is cast magnesium, due to the weight benefits provided.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 02-06-2016, 19:33
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
I once proposed to make some small engine parts out of magnesium alloy. Our company's insurance company threatened to cancel our policy immediately if we machined them in house. (They didn't work very well.)
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 02-06-2016, 20:54
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
The engine parts, or the insurance company?
Unread 02-06-2016, 20:58
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
This is a line of reasoning that's excellent. Risk v. reward is always an excellent comparison to run before selecting something outside the "norm."
Seems like a rather uninformed reaction for an insurance company. Magnesium has applications all over, and can be machined and used quite safely.
Just get a Bromotrifluoromethane extinguisher (Halon 1301) for areas where swarf and chips can gather, and all will be well. I've personally used a CBrF3 extinguisher on several fully ignited systems (one jet engine, two transmissions, and one interior cabin fire involving vaporized JP5) with great success.
Unread 02-06-2016, 21:29
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Wow, that's a lot of fires! Halon hasn't been produced in over 20 years, but it's still legal to use if you can find some; end of first section here.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 02-06-2016, 21:54
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Fine silicon sand works but not instantly and you need enough sand to bury the fire and cut off the oxygen.
The sand will also take heat from the magnesium helping to bring the mass below ignition.
Be very careful: you need to keep adding sand for some time while eliminating other things that can ignite and this means you need to be close to a hot fire. The sand itself can be fuel in small quantites mixed into the magnesium dust. You need to bury and not mix.
There are several YouTube videos that show mixtures of magnesium dust and sand flaring up: in these cases the sand to magnesium ratio is too low and the 2 are mixed.
Unread 02-06-2016, 22:44
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
USAF?
