Go to Post The students that I have known in FIRST over my 8 years of involvement have been far more inspired by the competition and some of the jaw dropping creations of "elite" teams than by anything that we made ourselves. - MattB703 [more]
  #31   Spotlight this post!
Unread 30-05-2016, 17:13
Re: Hex Kiwi Drive
Originally Posted by caume View Post
I should have added the pseudo to the original post, but this guy did it just how I did. The only difference is I would have field orientation
@caume: I'm curious to see how you would go about this. Please post your pseudocode with field orientation.
  #32   Spotlight this post!
Unread 30-05-2016, 20:48
wildwaffle's Avatar
wildwaffle wildwaffle is offline
FRC #1073 (The Force Team)
Rookie Year: 2015
wildwaffle is an unknown quantity at this point
Re: Hex Kiwi Drive
I might have missed someone saying this(correct me if they did), but a hexagonal robot would not be for pushing power. The design makes it easy to get out of being pinned. A perk to an omni wheel drivetrain is that if you know how to drive it well, then you can use another robot pushing you to your advantage. I know it's a different shaped chassis but team 33 in 2014 had a four omni wheel drivetrain. It wasn't omni directional unless another team applied the force to their side, and they used this to their advantage. (They won 2 districts, their district champs, and we're finalists in their division at worlds)
  #33   Spotlight this post!
Unread 30-05-2016, 22:37
caume's Avatar
caume caume is offline
AKA: Cameron Aume
FRC #3324 (Metrobots)
caume is infamous around these partscaume is infamous around these partscaume is infamous around these partscaume is infamous around these partscaume is infamous around these partscaume is infamous around these parts
Re: Hex Kiwi Drive
With this model, the battery is the back of the drive, the point opposite it is the front. flMotor would be the motor on the left side, closest the point opposite the battery.
Psuedocode:
if (fieldOriented) {
	cosA = cos(( target - gyroAngle ) * 3.14159 / 180 )
	sinA = sin(( target - gyroAngle ) * 3.14159 / 180 )
	x = (driverLX * cosA) - (driverLY * sinA)
	y = (driverLX * sinA) + (driverLY * cosA)
flMotor =   y*sind(60) + x*cosd(60) + turn
mlMotor =   y + turn
blMotor =   y*sind(60) - x*cosd(60) + turn
frMotor = - y*sind(60) - x*cosd(60) + turn
mrMotor = - y + turn
brMotor = - y/sind(60) + x/cosd(60) + turn
  #34   Spotlight this post!
Unread 01-06-2016, 13:19
TheMagicPenguin's Avatar
TheMagicPenguin TheMagicPenguin is offline
AKA: Josh B
FRC #1640 (Sab-BOT-Age)
TheMagicPenguin is an unknown quantity at this point
Re: Hex Kiwi Drive
I'm not 100% sure if having six wheels woild give you an advantage over having 3 or 4. The real advantage with this design is manuvrability.
Having a hexagon robot would allow you to not get pinned easily, and also the added advantage of having a smaller turning diameter.
I can attest to this advantage. In my first year of FTC we created a 4 omni wheel robot hexagon frame, and a round shell. Having this rounded shell let us cut corners that no one else could, not get pinned, and when turning we had no corners that could get caught on obstacles (i.e robots, field elements, field perminiter).
Here is an attached picture:
I'm not scard to have the unpopular opinion.
  #35   Spotlight this post!
Unread 05-06-2016, 22:21
Re: Hex Kiwi Drive
Psuedocode:
mlMotor =   y + turn
If I assume the following:
driverLX is the driver's field-centric move right command
driverLY is the driver's field-centric move downfield command
turn is the driver's rotate clockwise command
target is an angle offset which defines the "front" of the robot relative to the point opposite the battery
... then your code gives incorrect answers for the wheel speeds. See example with target=0 (front is defined as the point opposite the battery as stated above) and gyroAngle=0 (robot front is facing straight downfield).
Apparently not. The code I posted gives the correct wheel speeds for robot-centric driver FWD and STR commands.
To make that code give the correct wheel speeds for field-centric driver FWD and STR commands, just modify those commands as follows before calculating the wheel speeds:
temp =  FWD·cos(θ) + STR·sin(θ);
STR  = -FWD·sin(θ) + STR·cos(θ);
FWD  =  temp;
... where θ is the gyro angle, measured clockwise from straight downfield.
