Go to Post Many of us are engineers who value precision and accuracy in communication. Words mean things. - Alan Anderson [more]
Go Back   Chief Delphi > Technical > CAD
Unread 01-06-2016, 16:48
Chris is me's Avatar
AKA: Pinecone
Re: Robot Scooter
I would look at the general designs of other kick scooters and consider something closer to them for the front fork and steering tube. Right now it seems like your entire deck is mounted to just a 1" span of the steering tube, which makes it hard to support. Kick scooters generally use a headset bearing on a 2" or longer tube to attach the deck to the steering tube, and they don't build a frame around the front fork / wheel at all. If you're just using ball bearings or whatever to support the thrust load of the steer tube on the deck, that might not fly.
Unread 01-06-2016, 17:06
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Robot Scooter
Thanks for the advice! Still open to more if anyone else has suggestions. To reply to some comments:
Originally Posted by TheModMaster8 View Post
I would change the the front wheel brackets to 1/4 thick but other then that, it looks pretty sound to me.
That definitely sounds like something I could do to add strength.
Originally Posted by Chak View Post
I'm more concerned about electrical strength (if that's a thing). There are no motor controllers, breakers, etc. Running 3 CIMs on a 150lb robot is already a risky thing, so I figure running 3 CIMs on a 200+lb scooter can't be healthy.
I'm not 100% sure what you mean by electrical strength. As far as motor controllers and breakers go, they will go in front of the battery or under the CIMs, they just weren't CADed. I geared this lower than a normal FRC robot (17.2:1 total) so each CIM is traction limited to around 40 amps. It slowed it down more than I would have liked, but such is life.
the front wheel can't spin right now, but I'm sure that's just CAD.
Yeah I did that to make the CAD model look nice. In reality, the vertical tube is supported by a bushing that allows it to spin freely.
Also, it looks like your life would be so much easier if the front wheel is dead axle(edit: to clarify, dead axle would get rid of the front wheel brackets and a couple of bearings).
I agree dead axle would be easier. I chose live axle because I wanted to use the WCP pneumatic tires which are live axle only. In hindsight it would probably be easier to use the 6" AM pneumatic tires instead and run them dead axle. That will definitely be something I will look into for version 2.
I like how your CIMs are supported from the back, but I'm not sure how you're going to get them in and out if maintenance needs to happen.
You are very right; I did not plan well for maintenance. I suppose you would have to completely unbolt the back plate and then unscrew the CIM that needs replacing to slide it out, but that would not be fun. I might look into enlarging the hole in the back plate to go all the way around the CIM so the CIM can be slid out for replacement.
That's a good idea. I was really struggling with how to support that huge lever arm in so little space. Adding that front fork with a much longer bearing/bushing would probably work a lot better than what I have now, and it would allow for the scooter to be shorter overall. Something else for version 2.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
