Go to Post "It was defense killed the beast." - Justin [more]
Unread 01-06-2016, 18:01
Ashwin Adulla Ashwin Adulla is offline
FRC #0254
Ashwin Adulla is on a distinguished road
Re: Team 254 Presents: Dropshot Technical Binder 2016
Originally Posted by apache8080 View Post
What other wheels did you guys try out for the flywheel?
Do you guys use laser cut wood for majority of your prototypes? I assume that this makes prototyping easier and more accurate.
When is your code going to be released?
Thanks for this incredible resource.
We bagged and tagged our robot with 2 4" Colson wheels acting as our shooter. At CVR, we used 4 4" Colson wheels. At SVR and Champs, we used 2 4" Fairlane wheels with safety wire wrapped around it to stop it from expanding a significant amount past 5000 rpm.
Yes we did use a laser cutter for prototyping with wood and it greatly aided our prototyping process as we were able to quickly CAD and test different variables for our flywheel shooter (pg 13) such as hood angle, pulley ratios, ball traction, and moment of inertia. In addition we did use the laser cutter to test out different intakes and also to cut the hubs for our mechanum wheels.
As for the code, our programming team is performing a code clean and is planning to release it soon.
Unread 01-06-2016, 18:06
Knufire Knufire is offline
Do you have a source for the various SHARP sensors the technical binder mentions?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 01-06-2016, 18:16
apache8080 apache8080 is offline
Lead Programmer, Drive Coach, Scout
AKA: Rishi Desai
FRC #5677
apache8080 is on a distinguished road
Why did you guys switch from the Colson wheels to the Fairlane wheels?
Unread 01-06-2016, 18:33
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
could i get a reply to my question??
It was easy to miss
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
Unread 01-06-2016, 18:42
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
It was easy to miss
We have no plans to release the CAD of the robot but are happy to answer any questions you have.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 01-06-2016, 19:15
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
For the hood, it looks like you milled out a slot/track. Did you just use track rollers from McMaster or something different? How did you insure that the motion was smooth and didn't bind/be too lose and wobble?
For the Nexus 5 you have for vision, did you have to power it off of the robot? If so, did you just power via the USB or someother way?
Thanks for sharing, I (and my team) learn a lot from these.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 01-06-2016, 19:35
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
Internal Batteries are allowed for COTS computing devices. They did not open the phone up and remove the battery, instead they just ran a USB cable from the robo-rio to the phones charging/data port.
Unread 01-06-2016, 19:41
bigbeezy's Avatar
AKA: Bryan
Good to know, thanks!
Unread 01-06-2016, 19:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Do you guys do your laser cutting in house? Whether it is or not, I'm curious what make and model of laser you use.
Unread 01-06-2016, 20:59
FRC #0254
For the hood, it looks like you milled out a slot/track. Did you just use track rollers from McMaster or something different? How did you insure that the motion was smooth and didn't bind/be too lose and wobble?.
For our hood, we did mill out a slot on both hood plates and used what could best be described as a T-slot roller to move along the slot (I have attached a link of a T-slot roller to better visualize how our sector gear was able to move along the slot). In our case, the T-rollers, two on each side, were made out of plastic and turned down on the lathe. While assembling the hood, we did encounter an issue of the motion being somewhat rough due to the friction as the lateral surface of the T-slot roller contacted the inner surface of the slot. To fix it, we simply took a small file and filed down the lateral surface of the roller in addition to cleaning the slot with isopropyl alcohol (we used the same alcohol on the inside of our hanger weldment to ensure the inner tube would smoothly extend out for hanging). As the sector gear did extend past the halfway point on the slot, a slight wobble was noticeable by virtue of the distance between the bottom of the sector gear and the top of the hood plate shortening. However, this wobble was not deemed to be significant concern affecting our shot.
http://el34world.com/Misc/Cnc/images/Img_7561.jpg
Unread 08-01-2017, 17:03
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
I was curious on your climbing gearbox, what gear ratios did you use? Could you explain a bit more about it? Thanks and great document!!!
Unread Yesterday, 14:58
weller2811 weller2811 is offline
FRC #2811
weller2811 is an unknown quantity at this point
im trying to find the same wheels they used but i cant find any that are not extremely expensive on mcmastercarr.
Unread Yesterday, 15:12
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Yup. That's the drawback. They're $30-40 each.
Unread Yesterday, 15:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
They are sort of expensive individually but if you think about it, you need 1, maybe 2 per robot, they literally do not wear. They will last until well after you stop using the robot, they are very consistent, and it's the most critical system on your robot for scoring points outside of drive.
When you account for all those factors, $80 is downright cheap IMO.
2001-2004: Team 100
2006-Present: Team 254
Unread Yesterday, 15:42
Oh I'm think they're an excellent investment, that's for sure. My team kinda balked at the price tag, so I doubt they'll get any, but we'll see. Course, that's still cheaper than waiting until the last minute to buy all of the parts we want and paying for next day shipping.
