Vex Shift Rod through 3/8 Hex Shaft?
In CAD, the shifting rod has a diameter of 0.187 inches. So I'm wondering if custom shifting shafts can be made out of 3/8" hex shaft... or is that way too small to be considered safe?
Re: Vex Shift Rod through 3/8 Hex Shaft?
If it's a Ball shifter I would think probably not since the plunger inside the shifting shaft would likely be too big to accommodate 3/8" Hex. Can't speak to the possibility of doing it with a dog gear shifter though. IMO It would probably be easier to adapt a 3/8" hex onto the output end of a Vex gearbox than it would be to make a custom shifter for it. Not sure if that helps for your specific situation though. |
+1 on using a smaller custom rod.
Using a 3/8" hex shaft could be possible if you used custom Dog stuff, but ballshifting would be very tricky. On the plus side, you could use the 3/8" x 7/8" flanged bearings, which are very compact, for your dog gears. Using two different pitch gears on a shifter seems interesting but also risky. The main thing I would be worried about if you reduced the rod diameter is the little shifty bit (4-40 screw in WCP dogs). SW stress analysis could make sure it's safe. |
Use 1018 cold rolled steel. Stock bar is available in 0.125 and 0.1875 sizes.
You will need to have bearings in the pneumatic shift interface. Sticking with standard fractional sizes will make it easier to source bearings (R2 and R155). ** Edit- you could look at available Metric shaft as well. ** Last edited by InFlight : 01-06-2016 at 08:37. |
#7
Solidworks Simulation can help you calculate what effect the same torque has on the original 3/8" hex compared to the new one. Or you can plug in equations you find online for the strength of a tube versus a rod in torsion. Last edited by asid61 : 01-06-2016 at 18:18. |
#9
I guess this would counter that a dog gear doesn't make a great brake. Compared to a traditional brake, not so sure. I don't really know what traditional brakes look like (... is it a bike brake?). Quote:
#11
If this is an off-season project/design you might have enough to try some other methods of braking such as a disc brake.
#14
I've seen a lot of disc brakes in Recycle Rush for the lift mechanism. However, for my intentions I'm not sure if I would be able to fit one in the gearbox I'm making, even if it is a custom-manufactured part. You are right though. Offseason is a great time to explore new concepts and designs: something I failed to do last offseason by designing WAY too many drive gearboxes and drivetrains. |
#15
Sorry thats whats I get for responding on mobile. But yes hole smaller or shaft bigger. I would personally use a 3/16 shaft with a .201 or .196 clearance hole.
