Go to Post Competitions are won or lost far away from witnesses, ... In those long hours, is where we find inspiration in ourselves. For what inspires is not another's feats, but realize we have the power in ourselves to achieve that feat. - Mark Sheridan [more]
Unread 31-05-2016, 14:44
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Vex Shift Rod through 3/8 Hex Shaft?
In CAD, the shifting rod has a diameter of 0.187 inches. So I'm wondering if custom shifting shafts can be made out of 3/8" hex shaft... or is that way too small to be considered safe?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 31-05-2016, 16:30
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Vex Shift Rod through 3/8 Hex Shaft?
Are you referring to a ball shifter, dog gear shifter, or something else?
If it's a Ball shifter I would think probably not since the plunger inside the shifting shaft would likely be too big to accommodate 3/8" Hex. Can't speak to the possibility of doing it with a dog gear shifter though.
IMO It would probably be easier to adapt a 3/8" hex onto the output end of a Vex gearbox than it would be to make a custom shifter for it. Not sure if that helps for your specific situation though.
Unread 31-05-2016, 17:00
AKA: Daniel Koh
Team Role: CAD
Should have made that clear. I'm referring to the dog shifter rods, and in my newest CAD project the usage of 32dp gears from WCP and the 20dp 14t gear from VexPro requires the use of 3/8" hex. Perhaps your idea of a 3/8" hex adapter might work, except that I'm a bit concerned with how much space I have for it.
-KohKoh
Unread 31-05-2016, 18:45
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
You could make your own rod @ 3/16 diameter or something around the .15 diameter in steel.
R.C.
MadTown Robotics Team 1323
Unread 01-06-2016, 00:26
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
+1 on using a smaller custom rod.
Using a 3/8" hex shaft could be possible if you used custom Dog stuff, but ballshifting would be very tricky. On the plus side, you could use the 3/8" x 7/8" flanged bearings, which are very compact, for your dog gears.
Using two different pitch gears on a shifter seems interesting but also risky.
The main thing I would be worried about if you reduced the rod diameter is the little shifty bit (4-40 screw in WCP dogs). SW stress analysis could make sure it's safe.
Unread 01-06-2016, 01:39
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Use 1018 cold rolled steel. Stock bar is available in 0.125 and 0.1875 sizes.
You will need to have bearings in the pneumatic shift interface. Sticking with standard fractional sizes will make it easier to source bearings (R2 and R155).
** Edit- you could look at available Metric shaft as well. **
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 01-06-2016, 16:47
AKA: Daniel Koh
Team Role: CAD
My applications for using a shifter rod in a 3/8" hex shaft is for a brake for an arm gearbox. I would prefer to use COTS parts for the sake of machining time and because I know through experience that those work perfectly well without failure (as much). My main concern is if there's a limit to what size hole you can make in a shaft for the shifting rod to go through. Of course, I'm not going to make a hole in a shaft and leave only 0.01" of wall thickness, but I'm wondering if there is a general rule to follow.
-KohKoh
Unread 01-06-2016, 18:12
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
In general, hollowing out the center of an axle doesn't cause too many strength issues. IIRC 1/2" thunderhex is 92% as strong as standard 1/2" hex even with the hole through it.
Solidworks Simulation can help you calculate what effect the same torque has on the original 3/8" hex compared to the new one. Or you can plug in equations you find online for the strength of a tube versus a rod in torsion.
Unread 01-06-2016, 18:48
AdamHeard's Avatar
Lead Mentor
A dog gear doesn't make a great brake. It takes quite a bit of force to remove under torsional load compared to more traditional brakes.
Unread 01-06-2016, 19:14
AKA: Daniel Koh
Team Role: CAD
The gearboxes I designed for 649's shooter arm this year had a brake component, which utilized an AM shifter block with the rod and a custom part which acted as the dog. It was basically a plate that shifts against a urethane brake pad. I didn't see the thing in action very much, but people tell me that it worked very well during the competitions and has never needed maintenance (not too sure about never failing).
I guess this would counter that a dog gear doesn't make a great brake. Compared to a traditional brake, not so sure. I don't really know what traditional brakes look like (... is it a bike brake?).
Despite a horrific history final coming up tomorrow, I did some work today, and currently I'm expecting to make a 3/16" hole in the hex shaft for a custom shift rod with a diameter of 1/8". At some point I will run the shaft through Solidworks Simulation with these dimensions.
-KohKoh
Unread 01-06-2016, 19:47
R.C.'s Avatar
That is a lot of clearance for the shift rod. Why not make the hole bigger or the shift rod larger?
R.C.
Unread 01-06-2016, 20:07
AdamHeard's Avatar
Lead Mentor
What you described is a traditional brake. It relied on contact force and friction, not the interference of a dog in a mating part.
Unread 01-06-2016, 20:14
roboruler roboruler is offline
roboruler is infamous around these partsroboruler is infamous around these parts
If this is an off-season project/design you might have enough to try some other methods of braking such as a disc brake.
Unread 02-06-2016, 02:01
AKA: Daniel Koh
Team Role: CAD
If there's a lot of clearance, wouldn't you make the hole smaller?
Oh... I guess that gearbox I made had a traditional brake after all. Silly me.
I've seen a lot of disc brakes in Recycle Rush for the lift mechanism. However, for my intentions I'm not sure if I would be able to fit one in the gearbox I'm making, even if it is a custom-manufactured part. You are right though. Offseason is a great time to explore new concepts and designs: something I failed to do last offseason by designing WAY too many drive gearboxes and drivetrains.
-KohKoh
Unread 02-06-2016, 02:33
R.C.'s Avatar
Sorry thats whats I get for responding on mobile. But yes hole smaller or shaft bigger. I would personally use a 3/16 shaft with a .201 or .196 clearance hole.
R.C.
