Go to Post I suspect the GDC is enjoying watching teams wrap their heads around this ranking algorithm.... and is probably a bit surprised that it has taken teams so long to clue in to the options this ranking system presents to them. - dtengineering [more]
Unread 01-06-2016, 20:59
Ashwin Adulla Ashwin Adulla is offline
FRC #0254
Ashwin Adulla is on a distinguished road
Re: Team 254 Presents: Dropshot Technical Binder 2016
Originally Posted by bigbeezy View Post
For the hood, it looks like you milled out a slot/track. Did you just use track rollers from McMaster or something different? How did you insure that the motion was smooth and didn't bind/be too lose and wobble?.
For our hood, we did mill out a slot on both hood plates and used what could best be described as a T-slot roller to move along the slot (I have attached a link of a T-slot roller to better visualize how our sector gear was able to move along the slot). In our case, the T-rollers, two on each side, were made out of plastic and turned down on the lathe. While assembling the hood, we did encounter an issue of the motion being somewhat rough due to the friction as the lateral surface of the T-slot roller contacted the inner surface of the slot. To fix it, we simply took a small file and filed down the lateral surface of the roller in addition to cleaning the slot with isopropyl alcohol (we used the same alcohol on the inside of our hanger weldment to ensure the inner tube would smoothly extend out for hanging). As the sector gear did extend past the halfway point on the slot, a slight wobble was noticeable by virtue of the distance between the bottom of the sector gear and the top of the hood plate shortening. However, this wobble was not deemed to be significant concern affecting our shot.
http://el34world.com/Misc/Cnc/images/Img_7561.jpg
