Go to Post So, apparently I have my own division in nationals going by the search, "elgin clock division". Why was I not told about this? jeesh... - Elgin Clock [more]
Unread 06-02-2016, 07:33 PM
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
Re: Is Magnesium ok?
I once proposed to make some small engine parts out of magnesium alloy. Our company's insurance company threatened to cancel our policy immediately if we machined them in house. (They didn't work very well.)
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 06-02-2016, 08:54 PM
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
The engine parts, or the insurance company?
Unread 06-02-2016, 08:58 PM
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Originally Posted by DonRotolo View Post
As many have noted, Magnesium in typical form is no more dangerous than any other metal - even underwater. However, smaller chips or particles are able to be ignited, and then become extremely difficult to extinguish.
Yes a class D extinguisher has a chance, but hav limited effectiveness and are costly.
If you use the metal and don't need to machine it, you'll be fine. But if it needs to be machined, you are better off avoiding it. The risk is small but the consequences very large.
This is a line of reasoning that's excellent. Risk v. reward is always an excellent comparison to run before selecting something outside the "norm."
Seems like a rather uninformed reaction for an insurance company. Magnesium has applications all over, and can be machined and used quite safely.
Just get a Bromotrifluoromethane extinguisher (Halon 1301) for areas where swarf and chips can gather, and all will be well. I've personally used a CBrF3 extinguisher on several fully ignited systems (one jet engine, two transmissions, and one interior cabin fire involving vaporized JP5) with great success.
Unread 06-02-2016, 09:29 PM
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Wow, that's a lot of fires! Halon hasn't been produced in over 20 years, but it's still legal to use if you can find some; end of first section here.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 06-02-2016, 09:54 PM
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Fine silicon sand works but not instantly and you need enough sand to bury the fire and cut off the oxygen.
The sand will also take heat from the magnesium helping to bring the mass below ignition.
Be very careful: you need to keep adding sand for some time while eliminating other things that can ignite and this means you need to be close to a hot fire. The sand itself can be fuel in small quantites mixed into the magnesium dust. You need to bury and not mix.
There are several YouTube videos that show mixtures of magnesium dust and sand flaring up: in these cases the sand to magnesium ratio is too low and the 2 are mixed.
Unread 06-02-2016, 10:44 PM
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
USAF?
Unread 06-03-2016, 12:02 AM
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Alloys of various metals can have hugely differing properties in certain areas. throwing blanket statements about classes of materials isn't always appropriate. Please see the link below for some testing performed by the FAA in related to this very topic of conversation.
https://www.fire.tc.faa.gov/pdf/AR11-13.pdf
Knowing how badly it can go if not handled properly, I highly caution inexperienced users form considering magnesium in FIRST. That said, from experience, I can say that there is at least one Magnesium alloy that can withstand some impressively high temperatures after being machined into fine chips without burning
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 06-03-2016, 12:57 PM
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
The alloy from my previous post is AZ91D
Unread 06-03-2016, 04:14 PM
FRC #0114
The supply system that I worked inside of had enough Halon to last for quite a long time, so acquisition was never a problem.
Also of note are some of the AFFF agents used in fighting large (and very hot) fires, but these are utterly impractical and too expensive for an FRC team.
The principle of operation is the same: Remove the access to oxygen as rapidly and thoroughly as possible.
Originally Posted by adciv View Post
USAF?
USMC.
