Go to Post Are quadcopter rotors considered a pneumatic device? - bobbysq [more]
  #31   Spotlight this post!
Unread 03-06-2016, 00:02
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Re: Is Magnesium ok?
Alloys of various metals can have hugely differing properties in certain areas. throwing blanket statements about classes of materials isn't always appropriate. Please see the link below for some testing performed by the FAA in related to this very topic of conversation.
https://www.fire.tc.faa.gov/pdf/AR11-13.pdf
Knowing how badly it can go if not handled properly, I highly caution inexperienced users form considering magnesium in FIRST. That said, from experience, I can say that there is at least one Magnesium alloy that can withstand some impressively high temperatures after being machined into fine chips without burning
2004 - 2012: Team 1100
2013 - ????: Team 131
  #32   Spotlight this post!
Unread 03-06-2016, 12:57
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
The alloy from my previous post is AZ91D
  #33   Spotlight this post!
Unread 03-06-2016, 16:14
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Originally Posted by ctt956 View Post
Wow, that's a lot of fires! Halon hasn't been produced in over 20 years, but it's still legal to use if you can find some; end of first section here.
The supply system that I worked inside of had enough Halon to last for quite a long time, so acquisition was never a problem.
Also of note are some of the AFFF agents used in fighting large (and very hot) fires, but these are utterly impractical and too expensive for an FRC team.
The principle of operation is the same: Remove the access to oxygen as rapidly and thoroughly as possible.
Originally Posted by adciv View Post
USAF?
USMC.
