Go to Post There are a maximum of 80 balls in play . If all the balls are in the goals or out of play and the human players won't throw them back in, I guess the robots might try line dancing or doing the cha-cha. - Rick TYler [more]
Unread 03-06-2016, 00:25
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
pic: Team 5940 Offseason project
Unread 03-06-2016, 00:26
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
Re: pic: Team 5940 Offseason project
Where do you plan to drive it? School football field, gymnasium, parade, etc.?
Unread 03-06-2016, 00:31
thomasweese's Avatar
thomasweese thomasweese is offline
I may be stupid, but I'm also dumb.
Rookie Year: 2015
thomasweese is on a distinguished road
Sadly, our school doesn't have a football field or gymnasium... We're just in an auto body shop. Our plan with it (as I understand) is to license it out to other individuals, as well as use it to boost spirit for robotics and the school. Also it'll be helpful when showing prospective sponsors what we've accomplished. That's the plan, anyways.
Unread 03-06-2016, 00:35
juju_beans's Avatar
juju_beans juju_beans is offline
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
3647 is also making one though it is quite different (http://www.chiefdelphi.com/forums/sh...d.php?t=147697)
One big tip is to make the diameter of the t-shirts large enough so that air doesn't leak around the t-shirt when you shoot. We were testing our mechanism and couldn't figure out why it was going a really short distance and we found out it was because our t-shirts were rolled up too tight and didn't make a seal for air to push.
This is safe... right?
Unread 03-06-2016, 01:01
frcguy's Avatar
Unregistered Unuser
Also, I should add that the wheels are AndyMark performance and have no tread in the CAD, but will have tread when the robot is actually built.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
troy_dietz's Avatar
Rookie Year: 2015
In that case, I would recommend using pneumatic tires. (unless those are pneumatic hubs already, and you just haven't imported the tubes and tread)
Unread 03-06-2016, 01:18
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
What material are the little white things holding up the superstructure made of? They look kinda flimsy. The T-shirt shooter itself is not that heavy, so I suppose in theory you don't need much support. Still, it would be bad if the whole top of the robot collapses the moment someone sits on it.
Unread 03-06-2016, 01:22
frcguy's Avatar
Unregistered Unuser
The white things holding up the superstructure is 1" or 3/4" angle, if I remember correctly. It was modeled off the superstructure of our 2016 robot Focaccia, as we used a less substantial version of that to attach our top rails. We've put plenty of things on the top of our 2016 bot and it's held up just fine, so I think the shooter should be OK. Also, I don't think we're going to let anybody sit on it
Unread 03-06-2016, 07:28
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
Something you may want to consider, and maybe you have, is using 2 batteries instead of one. Team 343's t-shirt shooter uses 2 and it makes for a much longer run time for events especially since we run 2 on-board compressors to keep our air tank full. Our set-up does allow us to run on 1 battery, fully functional, which is also nice because sometimes there might only be 1 extra charged battery so we can swap around charged & almost dead batteries to keep it running continuously even with only 1 battery charger.
I didn't break it... this time.
Unread 03-06-2016, 10:33
juju_beans's Avatar
Rookie Year: 2016
3647 also has a parallel battery connector.
Sent from my SPH-L710 using Tapatalk
Unread 03-06-2016, 12:25
RoboChair's Avatar
AKA: Devin Castellucci
Or just use a car battery.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 03-06-2016, 13:30
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I would remove the bar stock supports and go with something much more robust. Unless you go with 1/4" stock you are going to have trouble with it bending when any force Is exerted. 1/4" would work but isn't easy to bend with most equipment. Looking at pictures of your bot comparing them really isn't a fair assessment. The bar stock just simply isn't strong enough and will cause headaches.
Try to make something out of more tubing whether angled 1x1s or something else.
Unread 03-06-2016, 13:35
frcguy's Avatar
Unregistered Unuser
Thanks for the advice, will do!
EDIT: Just talked with our CAD people and those are actually a placeholder for 1"x1" tube welded to the frame and superstructure. My bad!
Unread 08-06-2016, 02:04
Rookie Year: 2015
Thanks for the tip!
