Go to Post Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. - dtengineering [more]
Unread 06-03-2016, 07:30 AM
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
HEX broach too big for our manual press
So, we just received the HEX broach from andymark, and it doesn't fit into our manual 2 ton press.
The Broach is too long, and therefore we cant really use it.
Are there any solutions anyone has for this kind of a problem?
Will cutting the Broach somewhere in the middle, and therefore doing 2 presses every time we make a part work?
thanks!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 06-03-2016, 08:01 AM
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: HEX broach too big for our manual press
thanks!
DON'T CUT THE BROACH!!!!!!
Get a larger hydraulic press, trust me. Harbor Freight sells them or Amazon or wherever. It's worth the investment if you plan on broaching hex.
Unread 06-03-2016, 08:12 AM
Nate Laverdure's Avatar
FRC #2363
The other day I learned that the Harbor Freight 12- and 20-ton hydraulic shop presses have a fairly active mod community. Swag Off Road has some cool upgrade kits that you can buy (1, 2).
Unread 06-03-2016, 08:24 AM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
This.
Cutting a broach is a good way to throw away $200.
If the broach is only a little larger than the press, you might find that if you slot the broach into the hole of the part you want to broach before you put both into the press, the first few teeth in the broach will actually "skip" and the whole thing won't require as much clearance. Not guaranteed to work (also depends on material and hole tolerance) but something worth trying at least.
Unread 06-03-2016, 08:28 AM
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
A larger press is the ideal approach. You're not going to find a shorter broach.
We ran into the same problem this year. Our temporary fix was to create a secondary press platform below the one on the press (we have one like this that lets us pass longer material through the bottom of the press.). We'd put the material on the secondary platofrm, press as far as we could go, then the broach would be far enough into the press that we could use the original platform to finish the job.
I hope I described that correctly. Just remember that if you do this, it's important to make sure your secondary platform is parallel to the original platform so you don't broach crooked.
Unread 06-03-2016, 08:34 AM
Tottanka's Avatar
AKA: Liron Gurvitz
That looks pretty much exactly like the one we have.
Could you possible post a picture of the setup you guys made?
We tried it yesterday and realized that the lower platform has to be attached to the press and not to the table where it all sits, otherwise the press just lifts up when broaching.
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I keep our broach at work where I have a big enough arbor press. Broaches are very brittle. They need a straight push. The right size press is really the best.
Unread 06-03-2016, 08:38 AM
AnthonyDV AnthonyDV is offline
FRC #1678 (Citrus Circuits)
AnthonyDV is just really niceAnthonyDV is just really niceAnthonyDV is just really niceAnthonyDV is just really niceAnthonyDV is just really nice
It would help if you could provide more details such as the dimensions of the press and broach. if the dimensions are close, and if you have a lathe with a 4 jaw chuck, you can bore a hole into the ram of your arbor press to fit the back of your broach. I also suggest squaring the bottom of the hole with a modified drill bit or end mill. This and the amount of broach that starts in the part you are going to broach can give you an extra couple of inches.
Unread 06-03-2016, 08:52 AM
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
... Broach is too long ... Are there any solutions anyone has for this kind of a problem?
We have the same issue with the arbor press in our shop. Our solution was to start the broach using our lathe, which allows us to carefully align the broach to the hole and get the broach deep enough to now fit into our press. We try not to put too much load on the tool when it is in the lathe since we don't want to overload the lathe axially (which would damage the bearing in the lathe).
Ken
EDIT: The amount of load we put on the part+tool when they are in the lathe is very small - just enough to start 2-3 teeth of the broach - which is enough for it to then fit in our press.
Last edited by Ken Patton : 06-03-2016 at 07:50 PM. Reason: additional info added regarding load on the lathe, which is not recommended by some!
Unread 06-03-2016, 09:02 AM
Tottanka's Avatar
AKA: Liron Gurvitz
There is about a 6'' difference between the gap in the press and the length of the Broach, so it isn't really close to fitting ATM.
We will try both the Lathe broaching and the lower platform approach and post results here.
Unread 06-03-2016, 09:05 AM
Robotics Engineer
I'm in NJ for work and the press is in NH with the team. I'll see if I can get a team member to post a picture. We have a custom steel stand that our press is bolted to, making things a little easier to attach.
Unread 06-03-2016, 09:15 AM
Ken
I admit that I have done this, but on a big lathe. Some of Devin's (another mentor) projects have required far more force but I still can't recommend doing this.
Unread 06-03-2016, 09:54 AM
Bill Davis Bill Davis is offline
FRC #4063
Bill Davis is an unknown quantity at this point
However the method of driving the Hex Broach, be careful with your fingers. As the broach passes through the part being broached, the tooth next to enter will take skin with it.
Have you been caught broaching in the classroom yet?
Unread 06-03-2016, 10:00 AM
FRC #4063
Unread 06-03-2016, 10:03 AM
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Check out this thread for some ratcheting presses that are large enough for a 1/2 hex broach. I have a post on there on how we got the very sloppy Harbor Freight 12 ton shop press to work well with some simple mods. We really do need to find time to make a video of it in action.
-matto-
