Re: [FRC Blog] Radio Silence
I hope the new radios get a back up power supply.
Pretty sure that'd conflict with R31, as the only exception I've seen is a device that needs a battery to function and will not without it, eg. a smartphone used for vision (like 254).
Otherwise, I'd have stuck a capacitor on the radio to make sure it stays on in the event of a brown-out. |
The main problem, for me at least, is that the radio takes 90 seconds to boot... If they're working together on a custom FRC firmware why not make one that just boots faster and disabled unneeded features? EDIT: Approximately 90 seconds, numbers were based on a match I watched and wasn't exactly counting with a timer. Take with a grain of salt. Last edited by tjf : 03-06-2016 at 17:36. Reason: Clarification for quality. |
It's my understanding that the bulk of the OM5-AP bootup time is in loading and initializing the built-in web server interface to the device settings. If that were removed from the firmware package, it could probably boot in less than 30 seconds. It would also take away a lot of flexibility for teams to tweak their network setup. Given a couple of years with the same radio, I expect that the bootup time could be drastically slashed while providing teams with the appropriate tools to configure the device. That's probably not going to happen this year, though. |
One thing I wonder is that if when you configure the radio for field use, maybe the web dash could be disabled. There's no way anyway into the radio after it's been programmed without resetting it, so in competition mode that most likely would not be an issue. Especially as the firmware programmer and team flasher would work anyway without the dashboard.
#7
Are you saying "change is coming"?
#10
#11
#12
imo i think you are just bad at giving out rep might i suggest arbitrary negative rep towards the following accounts:
this one definitiely this one probably this one since he is 18 harassment is ok |
#14
By worse do you mean this? https://encrypted-tbn1.gstatic.com/i...rkKI5Vx9RamnoY
#15
The 1522 RevA is infamous for Einstein 2012. |
