Go to Post Or you can always say "we programmed it that way." - probizzle [more]
Unread 03-06-2016, 13:34
Chris is me's Avatar
AKA: Pinecone
Re: [FRC Blog] Radio Silence
Originally Posted by Jon Stratis View Post
I would say it's a top priority for our use... but for a vast majority of use cases, a boot time of 30 seconds versus one of 90 really doesn't make that much of a difference. When you're sitting at home and the power goes out and comes back, do you sit on your couch complaining that your home wifi router takes too long to reboot? And even if you do, does it happen often enough for boot time to be something you actively look for when picking your next router? Companies making routers know that most of the consumer base they're trying to attract won't really be impacted much by the boot time, and instead are looking for things those users do want - small size, strong signal, easy to set up, a nice UI, good security, customizability, etc. So all of that gets prioritized over boot time.
Besides, if it had amazing fast boot time, the engineers working on it wouldn't have any more excuses.
I meant a top engineering priority for FRC's engineers, not for the people that make routers for home use. When testing routers, a greater focus should be placed on boot time. There certainly are fast booting routers out there, though it's possible they are unsuitable for FRC for other reasons.
Unread 03-06-2016, 13:35
Originally Posted by tjf View Post
The main problem, for me at least, is that the radio takes 90 seconds to boot... If they're working together on a custom FRC firmware why not make one that just boots faster and disabled unneeded features?
I don't think I ever saw one take more than 60 seconds. 45-50 seconds was more typical. The rest of the delay some people are noticing is from the Driver Station sometimes taking upwards of 20 seconds to establish communication once the network connection is there. That appears to be a Windows networking thing.
It's my understanding that the bulk of the OM5-AP bootup time is in loading and initializing the built-in web server interface to the device settings. If that were removed from the firmware package, it could probably boot in less than 30 seconds. It would also take away a lot of flexibility for teams to tweak their network setup.
Given a couple of years with the same radio, I expect that the bootup time could be drastically slashed while providing teams with the appropriate tools to configure the device. That's probably not going to happen this year, though.
Unread 03-06-2016, 13:45
Volunteer, WPILib Contributor
no team (Waiting for 2021)
One thing I wonder is that if when you configure the radio for field use, maybe the web dash could be disabled. There's no way anyway into the radio after it's been programmed without resetting it, so in competition mode that most likely would not be an issue. Especially as the firmware programmer and team flasher would work anyway without the dashboard.
Team 4488 - Mentor 2013-2016
Unread 03-06-2016, 13:46
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Originally Posted by JohnFogarty View Post
+1
+9001
mDNS seemed to be finicky on this access port as well.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 03-06-2016, 13:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Conor Ryan View Post
I hope the new radios get a back up power supply.
Pretty sure that'd conflict with R31, as the only exception I've seen is a device that needs a battery to function and will not without it, eg. a smartphone used for vision (like 254).
Otherwise, I'd have stuck a capacitor on the radio to make sure it stays on in the event of a brown-out.
If FIRST is working with someone to spec a radio, I'm sure they would allow themselves to write rules that made it legal.
Last year's R31 exception to the main battery read:
Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.), provided they’re only used to power the COTS computing device and any peripheral COTS USB input devices connected to the COTS computing device and they are securely fastened to the ROBOT.
So, even with the same rule, a battery integral to the radio in its COTS state would have been legal. All they'd have to do is not disqualify it in a blue box or Q&A by deciding that the radio was something other than a computing device.
Unread 03-06-2016, 13:50
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Or we could just go with the fact that R31 currently does not exist for the 2017 season and does not matter in this discussion...
Unread 03-06-2016, 13:52
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Are you saying "change is coming"?
Unread 03-06-2016, 13:53
Flywheel Police
Unread 03-06-2016, 13:57
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Unread 03-06-2016, 13:58
Flywheel Police
Originally Posted by PayneTrain View Post
http://i.imgur.com/b7ysyoN.jpg
You must spread some Reputation around before giving it to PayneTrain again.
Well done sir.
Unread 03-06-2016, 14:02
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
Well done sir.
imo i think you are just bad at giving out rep might i suggest arbitrary negative rep towards the following accounts:
this one
definitiely this one
probably this one since he is 18 harassment is ok
Unread 03-06-2016, 14:04
marshall's Avatar
this one
Hey! I take back all the nice things I never said about you.
Unread 03-06-2016, 14:30
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
No question that boot time is a big downside of the OM5P-AN. It's ~60 seconds, compared to ~25 seconds for the previous d-link radio.
Considering the optimization target "number of seconds of robot-match time when the robot sat there unable to communicate", it is far superior to the d-link.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 03-06-2016, 14:31
bkahl's Avatar
bkahl bkahl is online now
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
this one
You definitely forgot a few, but this is a start!
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 03-06-2016, 14:52
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I'm 19 and a half minus 1 month okay!!
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
