Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
  #31   Spotlight this post!
Unread 26-05-2016, 08:25
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Lathe Suggestions
I think the used lathed market is very location & economy dependent. Where I am in the south, decent small lathes (anything under say a 12" swing) are hard to find & don't stay on the market long. Larger lathes typically need 3 phase and a dedicated space.
While way under the OP's budget, don't discount the 7 X xx Chinese lathes. They are supported by a large hobbyist group. Lots of available tooling & mods. While sold complete they should be thought of more as a kit. As long as you stay in their capability, they are as accurate as the operator. They do well on shafting and bushings. While no match for a Hardinge in good shape-- good luck finding a Hardinge for $1k with tooling. They can also be moved. If your reality a multi purpose classroom for a work space, they are not a bad choice.
  #32   Spotlight this post!
Unread 26-05-2016, 10:59
macman828's Avatar
macman828 macman828 is offline
Chief Engineer
AKA: Milton Martinez
FRC #4680 (Az-Tech Eagles)
macman828 is an unknown quantity at this point
My suggestion for lathe is this JET BD-920W. and guess what it is on Amazon.com JET has really good machines.
http://www.amazon.com/JET-BD-920W-La...ords=jet+lathe
We were fortunate to get this lathe donated to us (used)
It is compact but not too small, it worked great for all of our shafts this year.
FRC 1998 - 2000 ----Team 170 – Electrical & Programming Lead
FRC 2010 - 2014 ----Volunteer – Judge
FRC 2013 - Present -Team 4680 – Chief Engineer
  #33   Spotlight this post!
Unread 26-05-2016, 11:14
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
This particular lathe is a common one. It's not actually made by JET. They slap a label on it like a lot of other companies. I highly recommend this site for these lathes (used to be more extensive but times have changed):
https://littlemachineshop.com/produc...ory=1963256897
Also this guide and website can be helpful for these lathes:
http://www.akpilot.net/Rebuild%20Man...d%20Manual.pdf
http://bedair.org/9x20camlock/9x20project.html
  #34   Spotlight this post!
Unread 26-05-2016, 13:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That lathe is a piece of junk. You can make good parts with it but it is not a heavy duty machine. I would hate to pay $2k+ for it. We have one in our trailer and while it may have started out ok for small work and light cuts it is absolutely terrible now.
2001-2004: Team 100
2006-Present: Team 254
  #35   Spotlight this post!
Unread 26-05-2016, 14:53
RoboChair's Avatar
AKA: Devin Castellucci
I can second this and this will be the case with and mass manufactured Chinese lathe or mill. You will spend more time maintaining the thing than you will making parts, substantially more time if you want accurate parts.
I would never pay 2k for a lathe like that, maybe 1k all in with tooling if I needed a starter lathe and had no patience.
11 Years and counting! Over a third of my life has been spent with FRC.
  #36   Spotlight this post!
Unread 26-05-2016, 15:03
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Has anyone purchased the insanely cheap small ones from Harbor Freight? I know you get what you pay for, but will it work for turning down 1/2" hex shafts, creating spacers, and other minor operations? The downside seems the small travel length & chuck size.
We've gotten by for years without a lathe or a mill but I could see where a small one could come in handy for some operations that we simply can't do today. With a 20% off coupon you could probably snag this for under $500.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #37   Spotlight this post!
Unread 26-05-2016, 15:11
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
This has been discussed quite a bit, here are two posts about the subject I found with a quick search:
http://www.chiefdelphi.com/forums/sh...53&postcount=7
http://www.chiefdelphi.com/forums/sh...5&postcount=28
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #38   Spotlight this post!
Unread 26-05-2016, 15:15
Originally Posted by frcguy View Post
This has been discussed quite a bit, here are two post about the subject I found with a quick search:
Good finds! Thanks. Now to convince the team we need one
  #39   Spotlight this post!
Unread 26-05-2016, 16:10
frcguy's Avatar
#GearsAllDay
http://www.chiefdelphi.com/forums/sh...d.php?t=136550
This thread here has some good reasoning on why lathes (and mills) are important.
  #40   Spotlight this post!
Unread 26-05-2016, 16:29
RoboChair's Avatar
Those lathes are worth buying if you have limited need and budget. They can work fine but do take a lot to maintain. We had one donated for the 2014 build season and made all our shafts with it. I would do it again if I had to but I had to repair it at least 3 times during the season. If I had no lathe I would buy a 7x12 from Harbor Freight on sale, mod it with dials or cheap scales and be able to make parts.
  #41   Spotlight this post!
Unread 26-05-2016, 16:34
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
I am sure you will convince them. We use our Jet quite a bit for making axles and spacers it works great.
2012 Rookie Inspiration
Dallas Regional
  #42   Spotlight this post!
Unread 27-05-2016, 02:20
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
A small import lathe can easily machine custom axels, spacers, etc. Machining 1/2 inch 7075 hex shaft tends to push the limits of their ability.
You definitely need to be on top of the maintance game with these small lathes. If you machine much hex stock frequently, inspect the gibs for free play often.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
  #43   Spotlight this post!
Unread 05-06-2016, 09:26
eneubec1 eneubec1 is offline
FRC #5090 (Torque-Nados)
eneubec1 is an unknown quantity at this point
We purchased this lathe last year: http://www.micromark.com/microlux-7x...athe,9615.html
We were limited on space and could only handle a benchtop lathe.
We put the lathe ontop of this rolling workbench : http://www.costco.com/TRINITY-72%22-...100235671.html
You will also notice it has a longer bed than most others on the market.
It worked for everything we needed.
I'd recommend this lathe to anyone looking for a benchtop lathe.
FRC5090
  #44   Spotlight this post!
Unread 05-06-2016, 11:13
Underdog_19 Underdog_19 is offline
FRC #4909 (Bionics)
Underdog_19 has a spectacular aura aboutUnderdog_19 has a spectacular aura about
I believe we're looking at this one:
http://www.grizzly.com/products/10-x...campaign=zPage
Waiting to hear back from Grizzy regarding suggested accessories that work with it.
  #45   Spotlight this post!
Unread 07-06-2016, 15:18
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Any thought on this slightly larger Harbor Freight model (8x12)?
http://www.harborfreight.com/8-inch-...the-44859.html
