Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 05-06-2016, 20:00
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Long Range Wifi
Possible project needing designing.
Looking for the design of an antenna aiming device that can be controlled remotely (hardwired) from ground level, and need to be able to be controlled within a ~ 120 degrees left/right, and +- 15 degree elevation with 1 degree control steps or less in each direction. The weight of the dish is ~10 pounds. The entire assembly needs to be weather proof able to stay locked in position during heavy wind, rain, sleet, and snow. And as light as possible. It will be mounted atop a 21’ galvanized steel pipe 1-1/4” ID. The dish requires a ~2” mounting pipe to bolt to.
The cost needs to be as low as possible. Possibly two units required.
One dish mounted 80+ feet in the air atop a 60’ communications tower, the other 60 feet mounted in a tree.
The power source for the control needs to able to be carried either to base of tree/tower, or small enough to be carried up ladder with control panel.
This is for a long range wifi link, that needs to be fine tuned, but the actual dishes are too high above a safe standing/tie in point to tune other than lowering dish, setting elevation and re raising dish.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 05-06-2016, 23:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Long Range Wifi
Take a look at the offerings from Ubiquity.
Unread 06-06-2016, 00:13
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
I'll say the obvious.
It sounds like you need a commercial pan/tilt unit (PTU), with an appropriate weather resistance rating.
There are reasons why vendors can stay in business mass producing those, instead of being put out of business by home-brew devices.
Unread 06-06-2016, 00:47
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Long Range Wifi
Unless it does really need to be wifi, I recommend looking at the xBee line of products. They offer a wide variety of ranges and bandwidths to carry a wireless serial connection between two endpoints.
Unread 06-06-2016, 06:50
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Long Range Wifi
They make some off the shelf devices that hams are using locally to try to set up a network. You listed some tight tolerances, remember that trees are designed to move and twist in the wind. In my area there is always a 5-10 knot breeze blowing
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 06-06-2016, 07:41
Scott L.'s Avatar
Post Re: Long Range Wifi
I actually am using 2 AC pbe-500 Ubiquity dishes. They are great.
Some tree movement is ok, the dish returns to the same position when the wind dies down. The link is ~ 1.1km
Unread 06-06-2016, 12:50
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
If you are trying to link a pair of dish antennae, why do you need to be able to swing one of them through such a wide range (~120 Deg Az & +/- 15 Deg Elev)?
Also, my gut tells me that putting a weather-proof PTU, and a (small) dish antenna, and cabling, atop a 21' pipe atop a 60' tower, isn't going to end well. My gut is often wrong, but that seems like a bunch of mass at then end of a floppy lever arm.
It might not crash and burn, but don't you think it has a good chance of swaying/oscillating enough to foul up your data link?
Unread 06-06-2016, 20:18
Scott L.'s Avatar
Talking Re: Long Range Wifi
rethinking the specs, a pan of 45 degrees, and elevation of +-5 degrees would be more than enough for fine tuning. The elevation control is most important, because the entire mast pipe can be rotated. The 60' tower is guyed and stands atop 2+ cubic yards of concrete and with me at 60' has only slight sway. and the 21' foot pipe extends maybe 18' above that.
the dish mounted in the tree extends maybe 14' unsupported, and a tree was chosen as the cheapest option,$120, as opposed to installing another 60' tower at a cost of ~$1800
Unread 06-06-2016, 21:18
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
I'm worried most about the final 18' of pipe plus PTU and other payload, in the winds (different from ground level) at 80'.
Separate thought:
Can you align the router dish while at the top of the tower, then tweak the mounting fixture a known amount (use a shim?) (the tweak should be small) to get the dish close enough to the right elevation when it's later on the pipe, and has only moved a known distance higher than the spot whet you aligned it?.
Blake
PS: over several years, expect the tree to grow taller. The trees around my house have grown more into my satellite TV line-of-sight over the last 15 years.
Unread 07-06-2016, 08:04
Re: Long Range Wifi
Scott,
The tree with a dish is not a solution. Trees grow...
I would move to a yagi at the tree location. It has a bit wider aperture and doesn't need to stay pointed in exactly the right direction.
In reading your original specs, you have one dish mounted 80' feet up on a 60' tower? There is also some panel antennas that have pretty decent gain and a great front to back ratio. We are using those to link to the university next door (they rent space here). Approx path is a few hundred meters. They are powered over ethernet. I have to ask why you are mounting one at 80 feet. Do you have some obstacles?
Unread 07-06-2016, 09:59
Scott L.'s Avatar
Re: Long Range Wifi
Scott,
Yes, my obstacles are trees. The theoretical throughput is ~400mbps. When tuned the best can at the moment, I usually get 90-160mbps, which I'm fine with, but I have trees entering the fresnel zone, and link drops to unusable in rain with the leaves on the trees.
Unread 08-06-2016, 21:54
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Long Range Wifi
Yagis at both ends will give you plenty of link margin if it is only trees. I fear you are really hitting up against the speed of light.
WiFi has some very tight send-and-respond timing, particularly at high throughput. 1.1 km is a significant fraction of the ultimate limit for 802.11 distance, specifically because of the time it takes for the signal to travel - at the speed of light.
Oh, and your dish-on-a-pole-on-a-tower will come down in the first or second ice storm - you get those in PA, right? Don't ask how I know.
Oh, and what Al said about trees. (But, perversely, although a tree WILL grow, your antenna won't get any higher off the ground as it does).
I encourage you to learn about WiFi link timing and do the math for 1.1 km. You will be surprised at how tenuous that link is, but not for signal strength. Try 802.16 instead, built exactly for what you want to do.
Unread 08-06-2016, 22:57
Scott L.'s Avatar
Re: Long Range Wifi
https://dl.ubnt.com/datasheets/Power...Beam5ac_DS.pdf
The dishes are the PBE-5AC-500. 5.8GHZ Carrier using 80MHz channel.
Light travels 300,000km/s, so a 1.1km distance would take 3.67uS one way
Tower is a rohn 25G series.
21'pipe is 1-1/4" ID with 1.66"OD
Unread 08-06-2016, 23:38
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: Long Range Wifi
If you do have any doubts about your expected throughput, and if you already have the equipment, take it to the two sides of an easily accessible 1.1km wide unobstructed "valley", and then see how much throughput you can get. That will put an upper bound on what you can try to achieve shooting through the trees.
In the same vein, attach some weight lifting weights to the pole to represent your equipment, plus ice & snow, then mount the pole on something sturdy (at ground level), then pull hard on its top with a rope to mimic a strong wind. See what happens (be out of the way if anything breaks loose).
For the weight and wind loadng test, if you can attach the pole to something at ground level using the same brackets you want to use to lock it in place up in the air, even better. See how they hold up when you abuse them.
Unread 09-06-2016, 04:09
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: Long Range Wifi
Not wanting to derail Scott's question, but much along the same lines...
Any suggestions or ideas on a ~750' run thru some trees and the tops of 2-3 houses?
I could try to elevate but that would only get me away from maybe 2 of the houses, trees would still be in the way.
