Go to Post Like many researchers before me, I look and read about what my peers are doing and developing, and then incorperate the best of them into my ideas or change my focus because of them. - Wetzel [more]
Unread 03-06-2016, 10:10
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
Re: HEX broach too big for our manual press
We had the same problem when we started using hex. We use one of these for broaching and just about any other press needs...not too big, but plenty of force. There is a floor version as well.
Dake 10 ton press.
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 03-06-2016, 10:25
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Like Anthony said, we have used lathes and mill knees in the past to hex broach. Neither are recommended.
We've spent the last few years scouring Craigslist and found a 5 ton/8 ton compound arbor press similar to this: http://www.machine-recycling.com/Sep...bor-press.php6
The travel is plenty and the press is very rigid/square. As a bonus, I'm pretty sure the tool will outlive any of us on the team
If you spend long enough looking, you can find a good deal on one. We got ours for $550.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 03-06-2016, 10:31
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Either bolt the press to a steel frame suitable to support the pressure and put blocks under the work piece when you run out of travel or:
I bought this recently and it works fine for the AndyMark (Dumont) broach:
http://www.ebay.com/itm/261742003018
Mine is currently in my garage on a custom cart made of 2x4 and 3/4 plywood with locking casters. It was lifted with a car engine hoist. Shipping from Ohio took 1.2 days to NJ. The ram has a 1/2" hole in the end and there is a metric set bolt which doubles as a stop when the ram is lifted. Put a longer metric bolt in there and you are all set to broach. Mine has a casting void at the bottom which makes no difference to operation.
Also consider this (see Craig Roys post above):
http://www.ebay.com/itm/261956665389
The advantage of the Dake press is the pressure gauge.
You can use a short ram hydrualic piston from Harbor Freight filled with glycerin as a pressure gauge plate on the previously listed ratcheting arbor press.
Unread 03-06-2016, 12:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Ours fits just barely on our Grizzly arbor press. They don't sell the exact model we have anymore but judging by the ones they do have, it's probably a 5-ton. 2-ton is pretty small for broaching 1/2" hex. I'm a big guy, and we've broached certain things 1/2" hex (steel) to where I had a 4 foot pipe over the handle and was just about hanging off of that to get it to go. On a two ton press, you'll struggle with anything more than 6061 aluminum, about 1/2" length through bore.
If you do want to keep your press and use it with longer broaches and things, there's two things you can do. You can chuck up the arbor in a 4-jaw chuck on a lathe and drill a hole into it, or you can build a custom table for your press, that has a sturdy place for you to set the part below the press.
Unread 03-06-2016, 13:43
Hikel team 319 Hikel team 319 is offline
FRC #0319
Hikel team 319 is an unknown quantity at this point
this is the setup that 319 uses as Ty was explaining it earlier in this thread
Unread 03-06-2016, 14:34
Jared's Avatar
Jared Jared is offline
Don't broach using a lathe or mill - the thrust bearings aren't designed to be loaded while they aren't spinning and aren't usually cheap and easy to replace. Also, you'll likely end up moving the head on your mill, and you'll need to tram the head before you use it as a mill again.
Unread 03-06-2016, 15:01
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
My that is a awfully big C-clamp you have there.
Unread 06-06-2016, 01:19
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by Tottanka View Post
So, we just received the HEX broach from andymark, and it doesn't fit into our manual 2 ton press.
The Broach is too long, and therefore we cant really use it.
Are there any solutions anyone has for this kind of a problem?
Will cutting the Broach somewhere in the middle, and therefore doing 2 presses every time we make a part work?
thanks!
Remove the arbor of your arbor press. Drill a hole into it with a lathe or some fancy jig so the hole is straight(does not need to be centered). Operate your broach as a 2 step process, start with it in the hole, push it the rest of the way through with the flat to the side of your hole.
Even if it doesn't fully fix it, it still increases the "Effective Travel"
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 06-06-2016, 01:20
RoboChair's Avatar
I've broached with the knee of our bridgeport mill against the turret arm. It works and it sucks, and it isn't detrimental to the machine if done right.
Unread 06-06-2016, 01:55
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Can you explain how to do it right?
Unread 06-06-2016, 02:25
4911 BR 4911 BR is offline
FRC #4911
4911 BR is an unknown quantity at this point
I've done this using the knee. It is a two person job. One to hold a support tube, the part, and the broach. And one person to operate the knee.
Unread 06-06-2016, 02:29
RoboChair's Avatar
So, you will need a few things.
A knee mill
A hex broach(or other broach)
The part you want a fancy hole in
Some piece of metal with square ends(like really square, you have a knee mill there is no excuse) and a hole through the middle
Your support piece needs to be at least as long as the broach or have several progressively longer pieces if you find the total travel to be in issue. Don't use multiple pieces to support this set up, it's a good way to break your $200 broach that you are trying to use cheaply. Take your sweet time.
Place your first or only support block(tube) on the back of the knee ways and make sure it is stable. Place your work on top of the support so that it lines up with the hole. Line your broach up with the whole set up doing as best as you can to have everything perfectly straight, take your time please. When you are sure you are good to go begin cranking the knee of your mill up slowly until it makes contact with some part of the turret(the part that nobody EVER moves back and forth on a mill but you could if you wanted) slides on a flat part only. Ours has a dovetail slide and we used the further down bottom flange of the dovetail. If you plan to do this often, just set up the turret so it is set up perfectly over the Y-axis knee ways.
This next part is really important.
When you are sure it's settled and ready to broach, crank the knee up a full turn and back it off to let the broach recenter itself. Keep doing this full turn back off step until you run out of travel, repeat until done. The backing off step may not be 100% needed, but it will prevent the chance of many unwanted things happening to your set up.
EDIT: Done carefully, it can be managed with one person, but 2 makes it far easier and you can take turns cranking.
Unread 06-06-2016, 11:09
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Another thought:
While all of this advice is well and good, here is a simple solution. Consider making the size of your starting hole larger. If you start with a bigger starting hole, then the broach will fit down into the hole further and you may not need to buy a new arbor press or create a new setup suggested by the brilliant people in this thread.
For instance, if you are creating a 1/2" Hex hole, start out with a 0.520" hole instead of a 0.500" hole. For most applications, I contend that you don't need the middle of the hex flat to transmit the torque, only the outer 1/3 of the hex flat. (If you want to test this, put a hex wrench on a piece of aluminum hex stock. Hold the stock in a vice and torque the wrench until the aluminum is stripped. You will see that the middle of the hex flat is unused. This is actually the same thing I did when designing the churro many years back.)
Here is a pic to show what I mean:
Hope this helps!
Andy B.
Unread 06-06-2016, 14:16
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
My only concern with this would be that it might be harder to keep the broach aligned with the bore since you no longer are relying on the fit between the .500 dia shank on the broach and the hole in the part to ensure initial alignment.
Otherwise this is a perfectly good way to broach something. You'll see that any parts that have been rotary broached will end up with a rounded center and only have flats on the corners, like Andy drew above, since the broach requires some additional clearance over nominal.
At some point the best solution is just to drop $500 on a new arbor press that is actually large enough so that you can do this easily and more repeatably, if you're going to be broaching a lot of parts.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-06-2016, 19:24
Dpaulson Dpaulson is offline
FRC #0599
Dpaulson is an unknown quantity at this point
I have been doing shafts and broaching a long time. We always start the hex broach in the lathe with the piece in the chuck and a center in the tail stock.As we get 3 or 4 inches in we move to the arbor press but I find no problem doing the process in the lathe. Drill a big hole a lot more force then the broach. Yes arbor press is fine for broaching a keyway but that hex broach has to be straight Most of this work is in alumimun
Dave Paulson
15 years mentoring
Team 599
